AD7747 ATMEGA 2560 Read Issues
Hello! Thanks to all for reading. I am using an AD7747 in single-ended mode with a range up to 8.192pf to measure proximity between two parallel plates (or at least i'm trying to.)
Right now the data I'm getting is not changing at all. There are 3 capacitance registers that I am reading and they just aren't changing as I move my plates.
Here is my code,
    //|     AD7747 Capacitive Sensor                                                         |
    //|   Based on code by  MiG found at:http://forum.arduino.cc/index.php/topic,11882.0.html|                                           |
    //|  Author: Aidan Williamson                   |
    //|  Written: 7/3/2014        |
    //|  ad7747 datasheet:http://www.analog.com/static/imported-files/data_sheets/AD7747.pdf |
    #include <Wire.h>                  //include the library for i2c communication
     int capreadybit = (bitRead(TWDR,0));  //initialize variable readybit to be two wire data register's lsb
      Wire.begin();                   //sets up i2c for operation
      Serial.begin(9600);             // we will monitor this via serial cable
      Wire.beginTransmission(0x48);
      Wire.write(0xBF);
      Wire.endTransmission();
      delay(4);
      Wire.beginTransmission(0x48);   // begins write cycle
      Wire.write(0x07);              //address pointer for cap setup register
      Wire.write(0xA0);              //b'10100000' found from datasheet page 16
      Wire.endTransmission();        //ends write cycle
      delay(4);                      // Wait for data to clock out? I'm not 100% sure why this delay is here (or why it's 4ms)
      Wire.beginTransmission(0x48);   //begins transmission again
      Wire.write(0x09);              //address pointer for capacitive channel excitation register
      Wire.write(0x0E);              //recommended value from datasheet
      delay(4);
      Wire.write(0x0A);              //address pointer for the configuration register
      Wire.write(0x21);              //b'00100001' for continuous conversion, arbitrary VTF setting, and mid-range capacitive conversion time
      Wire.write(0x0B);              //CAP DAC A Register address (Positive pin data)
      Wire.write(0x80);               //b'10000000' for enable Cap DAC A
      Serial.println("Hello!");        //test to make sure serial connection is working
    void readycheck()
      Wire.beginTransmission(0x48);   //talking to chip
      Wire.write(byte(0x00));                  //status register address
      Wire.requestFrom(0x48,1);       //request status register data
      delay(100);
      while(capreadybit == 0)             //if the ADC has data for us then this bit will be low
         loop();                      //goto the capacitance read program
    void loop()                      //read capacitance
        Wire.beginTransmission(0x48); //arduino asks for data from ad7747
        Wire.write(0x01);             //set address point to capacitive DAC register 1
        Wire.endTransmission();       //pointer is set so now we can read the data
        Wire.requestFrom(0x48,3);     //reads data from cap DAC registers 1-3
        while(Wire.available())
         unsigned char hi;
         unsigned char mid;
         unsigned char lo;            //1 byte numbers
         long capacitance;            //will be a 3byte number
         float pf;                    //scaled value of capacitance
         hi=Wire.read();
         mid=Wire.read();
         lo=Wire.read();
         capacitance=(hi<<16)+(mid<<8)+lo-0x800000;  //shift high left 16 bits, shift mid left 8 bits, add lo and subtract 0x800000 for zero scale
         pf=(float)capacitance/(float)0x800000*8.192f; //8.192 is maximum capacitance reading
         Serial.print(pf, DEC); //prints the capacitance data in decimal through serial port
         Serial.print(",");
The board I'm using is shown here: http://opensourceecology.org/w/images/1/1d/CapSenseV1Brd.png
I mainly want to know if there are any flaws with my code. This is my first project with arduino and my first in a higher level language. I have experience working in assembly language but not C. So, yeah, if anything stands out please let me know.
Thanks!!!
You can't have a function called loop( ) like that.
You need to understand the role of the arduino loop( ) function.
Insert Quote
Ok. Should I make my "readycheck" my loop and call a different function from it?
On the arduino, loop( ) is a function which is executed over and over again, and anything else that you want to do, gets called from loop( ).
You don't call the loop( ) function from anywhere, the arduino does that for you.
You need to have a proper loop function to do this, and call your other function something else.
Ok I have come to that realization yesterday with your help. Here is my code now. It is scattered with some serial prints that are there for making sure all parts of the loop are reached. I am still reading a maximum value of capacitance at all times. If there are no glaring issues with this then I will try replacing the chip. It could be that there is parasitic capacitance of the same or higher order as my capacitance test jig: Capacitance Test Jig - YouTube
    //|  Author: Aidan Williamson  (advised by Paul Neelands)            |
     //int capreadybit = (bitRead(TWDR,0));  //initialize variable readybit to be two wire data register's lsb
      Wire.write(0xBF);
      Wire.write(0x00);
      delay(4);
      delay(4);
      Wire.write(0x80);               //b'10111111' for enable Cap DAC A
      int readycap;
      readycap=Wire.read();
      if((readycap&0x1)==0){                // ready?
        Serial.println("Data Ready");
        Serial.println("Data Incoming");
        while(Wire.available()){
          unsigned char hi,mid,lo;      //1 byte numbers
          hi=Wire.read();
          mid=Wire.read();
          lo=Wire.read();
          pf=(float)capacitance*-1/(float)0x800000*8.192f;
          Serial.print(",");
    Serial.println("Loop Done");
    Serial.println("  ");
