Hi everyone,
Im currently working on a AD9833 based signal generator.
Here I have an issue, the signal flickers which I believe is caused by the fact that the state of generator is continously updated in void loop().
Here I provide my code:
#include <SPI.h>
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
//Map pins
const int FSYNC = 10;
const int PUSH = 2;
const int testButt = 3;
//Define contants for AD9833
const int SINE = 0x2000; //0010 0000 0000 0000
const int SQUARE = 0x2028; //0010 0000 0010 1000
const int TRIANGLE = 0x2002; //0010 0000 0000 0010
//set some default values
int waveform = SINE; //default waveform is sine.
long freq = 10000; //default frequency is 1 kHz.
int x = 0b0001; //cyclic for shape change
int step = 1; //default is 10 Hz step.
enum Mode {FREQ,SHAPE,STEP,AMPL};
Mode mode = FREQ;
void write_frequency(long frequency){
int MSB,LSB;
int phase = 0;
long calculated_freq_word;
float AD9833Val = 0.00000000;
AD9833Val = (((float)(frequency)) / 25000000); // zegar DDS 25 MHz
calculated_freq_word = AD9833Val * 0x10000000;
MSB = (int)((calculated_freq_word & 0xFFFC000) >> 14);
LSB = (int)(calculated_freq_word & 0x3FFF);
LSB |= 0x4000;
MSB |= 0x4000;
phase &= 0xC000;
write_register(0x2100);
write_register(LSB);
write_register(MSB);
write_register(phase);
write_register(waveform);
void write_register(uint16_t data){
SPI.setDataMode(SPI_MODE2); //IMPORTANT: This is the right SPI mode for AD9833.
digitalWrite(FSYNC, LOW); //Set FSYNC low
delayMicroseconds(10); //prepare for transfer
SPI.transfer(highByte(data));
SPI.transfer(lowByte(data));
digitalWrite(FSYNC, HIGH); //Bring FSYNC back to high
void reset(){
write_register(0x100);
delay(10);
void display(){
void check_button(){
if(!digitalRead(PUSH)){ //button pushed, connected to ground (LOW)
if (mode == Mode::FREQ)
mode = SHAPE;
else if (mode == Mode::SHAPE)
mode = STEP;
else if (mode == Mode::STEP)
mode = AMPL;
else if (mode == Mode::AMPL)
mode = FREQ;
delay(50); //some delay for bouncing
printMode(); //debug function
void printMode(){ //debug function
if (mode == Mode::FREQ) {
Serial.println("Mode: FREQ");
else if (mode == Mode::SHAPE){
Serial.println("Mode: SHAPE");
else if (mode == Mode::STEP){
Serial.println("Mode: STEP");
else if (mode == Mode::AMPL){
Serial.println("Mode: AMPL");
void adjust(){
if (mode == Mode::FREQ){
if (true){ //right
freq+=step;
else if (false){ //left
freq-=step;
int dir = 0;
if(!digitalRead(testButt)){ //check encoder rotation //1 = SINE, 2 = SQUARE, 4 = TRIANGLE
x <<= 1;
if (x > 4)
x = 0b0001;
if (x == 1)
waveform = SINE;
else if (x == 2)
waveform = SQUARE;
else if (x == 4)
waveform = TRIANGLE;
else if(false){
if (x == 1){
x = 0b0100;
else{
x >>= 1;
if(x == 1)
waveform = SINE;
else if (x == 2){
waveform = SQUARE;
if (true){ //right
if (step < 1000000)
step*=10;
delay(100);
if(step != 1){
step/=10;
delay(100);
//nop
void setup(){
pinMode(PUSH,INPUT_PULLUP);
pinMode(testButt,INPUT_PULLUP);
SPI.begin(); //start the SPI communication
reset(); //reset the AD9833 module
write_frequency(freq); //write default: Sine 1 kHz
void loop(){
//check_button(); //switch mode if button was pressed
//adjust(); //adjust values with encoder
write_frequency(freq); //set parameters
//delay(200); //some delay is desired
delay(100);
This flicker seems to go away when we set relatively high frequency like 200 kHz or so.
I tried to play with delay() but no luck yet.
Does anyone know a suitable soltution to this problem?
Thanks in advance.
Kind regrads
