AD9834 Control Amplitude
Hello i have AD9834 Board Generator I found the code that control the frequency.
Can someone modify thecode that are capable to set and the amplitude. I try to do but no result.
#include "Wire.h"
#define MAX5381 0x64
#include "TimerOne.h"
int TimerUpdateRate = 1000;
const int SOURCE = 0;
const int FSYNC = 10;
const int SDATA = 11;
const int SCLK = 13;
const float CRYSTAL = 75000000.0 ;
const int SINE = 0x2000;
const int SQUARE = 0x2020;
const int TRIANGLE = 0x2002;
unsigned long FREQ = 1000;
char Command ;
byte byteRead ;
void UpdateDDS(unsigned int data){
  unsigned int pointer = 0x8000;
  digitalWrite(FSYNC, LOW);     // AND NOW : WAIT 5 ns
  for (int i=0; i<16; i++){
   if ((data & pointer) > 0) { digitalWrite(SDATA, HIGH); }
      else { digitalWrite(SDATA, LOW); }
    digitalWrite(SCLK, LOW);
    digitalWrite(SCLK, HIGH);
    pointer = pointer >> 1 ;
  digitalWrite(FSYNC, HIGH);
void UpdateFreq(long FREQ, int WAVE){
  long FTW = (FREQ * pow(2, 28)) / CRYSTAL;
  if (WAVE == SQUARE) FTW = FTW << 1;
  unsigned int MSB = (int)((FTW & 0xFFFC000) >> 14);
  unsigned int LSB = (int)(FTW & 0x3FFF);
  LSB |= 0x4000;
  MSB |= 0x4000;
  UpdateDDS(0x2100);
  UpdateDDS(LSB);
  UpdateDDS(MSB);
  UpdateDDS(0xC000);
  UpdateDDS(WAVE);
void ReadUserInput()
  boolean ende = false ;
  FREQ = 0;
  while ( ( Serial.available() ) || ( ende == false ) )
      byteRead = Serial.read();
      if ( byteRead == 10 ){ ende = true ; }
      if (( byteRead > 64 ) & (byteRead < 91)) {
        Command = byteRead ; }                      // A..Z
      if (( byteRead > 47 ) & (byteRead < 58)) {
        FREQ = FREQ * 10;
        FREQ = FREQ + byteRead - 48 ; }             // 0..9
  pinMode(SOURCE, OUTPUT);
  pinMode(FSYNC, OUTPUT);
  pinMode(SDATA, OUTPUT);
  pinMode(SCLK, OUTPUT);
  digitalWrite(SOURCE, LOW);
  Wire.begin();
  delay(2000);
  Serial.println("AD9834 Micro Waveform Generator");
  Serial.println("-------------------------------------------------------");
  Serial.println("COMMAND  : [WAVEFORM]+[FREQUENCY IN HERTZ]");
  Serial.println("WAVEFORM : S-SINE, T-TRIANGLE, R-RECTANGLE, A-ARBITRARY");
  Serial.println("E.G:: S1000 OUTPUTS A SINE AT 1000 Hz");
  Serial.println("Max. Const. Value :: S12500000");
  Serial.println("Interval:: 100 Hz-18000000 Hz");
  UpdateDDS(0x2100);
  UpdateDDS(0x50C7);
  UpdateDDS(0x4000);
  UpdateDDS(0xC000);
  UpdateDDS(0x2000);
  delay(999);
    ReadUserInput();
    switch (Command)
      case 82 :
        Serial.print("\nRECTANGLE, FREQ = ");
        Serial.print(FREQ,DEC);Serial.println(" Hz");
        UpdateFreq(FREQ, SQUARE);
        Serial.println("O.K.");
      case 83 :
        Serial.print("\nSINE, FREQ = ");
        UpdateFreq(FREQ, SINE);
      case 84 :
        Serial.print("\nTRIANGLE, FREQ = ");
        UpdateFreq(FREQ, TRIANGLE);
      default:
        Serial.println("\nUnknown Command.");
        Serial.println("Try again :-)");
        delay(100);
The AD9834 does not have built-in ability to change the output amplitude. You will need a digital potentiometer or a DAC.
The AD9834 provides a pin for amplitude control but the PWM output of an Arduino is not appropriate.
Perhaps there is a DAC or a digital potentiometer on your board for this purpose but you have not told us what board you have.
