I found this example code on Sparkfun to generate the frequency of 1MHz.
* \example Fixed.pde
* Fixed-frequency sinusoid generator.
* This example produces a 1MHz sinusoidal signal using the %AD9835 class
* from the Synthesis library.
#include <SPI.h>
#include "AD9835.h"
// We begin by creating the AD9835 object with the pin assignments
// that are used. If another pinout is used, this must be
// modified.
AD9835 dds(
7, // FSYNC
3, // SCLK
2, // SDATA
6, // FSEL
5, // PSEL1
4, // PSEL0
50000000 // hzMasterClockFrequency (50MHz)
// We must first set up all of our output pins.
dds.begin();
// We then set the board to produce a 1MHz signal.
dds.setFrequencyHz(0, 1000000);
dds.selectFrequencyRegister(0);
// Without modulation the choice of phase offset does not matter,
// but we set it to zero for good measure.
dds.setPhaseDeg(0,0);
dds.selectPhaseRegister(0);
// Finally, we turn on the IC.
dds.enable();
while(1)
delay(10);
this is the link for the library file: GitHub - LachlanGunn/Synthesis: DDS Support for Arduino
I am getting this long long error when I compile it:
AD9835.cpp:47:22: error: WProgram.h: No such file or directory
In file included from AD9835.cpp:48:
AD9835.h:22: error: 'byte' has not been declared
AD9835.h:24: error: 'byte' has not been declared
AD9835.h:25: error: 'byte' has not been declared
AD9835.h:28: error: 'byte' has not been declared
AD9835.h:29: error: 'byte' has not been declared
AD9835.h:30: error: 'byte' has not been declared
AD9835.h:34: error: 'byte' has not been declared
AD9835.cpp:169: error: prototype for 'void AD9835::setFrequencyCode(byte, long unsigned int)' does not match any in class 'AD9835'
AD9835.h:23: error: candidate is: void AD9835::setFrequencyCode(int, long unsigned int)
AD9835.cpp:195: error: prototype for 'void AD9835::setFrequencyHz(byte, long unsigned int)' does not match any in class 'AD9835'
AD9835.h:24: error: candidate is: void AD9835::setFrequencyHz(int, long unsigned int)
AD9835.cpp:208: error: prototype for 'void AD9835::selectFrequencyRegister(byte)' does not match any in class 'AD9835'
AD9835.h:25: error: candidate is: void AD9835::selectFrequencyRegister(int)
AD9835.cpp:219: error: prototype for 'void AD9835::setPhaseCode(byte, long unsigned int)' does not match any in class 'AD9835'
AD9835.h:28: error: candidate is: void AD9835::setPhaseCode(int, long unsigned int)
AD9835.cpp:240: error: prototype for 'void AD9835::setPhaseDeg(byte, int)' does not match any in class 'AD9835'
AD9835.h:29: error: candidate is: void AD9835::setPhaseDeg(int, int)
AD9835.cpp:253: error: prototype for 'void AD9835::selectPhaseRegister(byte)' does not match any in class 'AD9835'
AD9835.h:30: error: candidate is: void AD9835::selectPhaseRegister(int)
AD9835.cpp:312: error: prototype for 'void AD9835::writeSPI(byte, byte)' does not match any in class 'AD9835'
AD9835.h:34: error: candidate is: void AD9835::writeSPI(int, int)
Please help I m stuck...
