AD9910 External control With Arduino
Hey people ,
I'm try load the registers of AD9910 with a Mbed but isn't work. Now i'm try with Arduino uno, anyone knows a code for a load control AD9910 !?
Thanks a lot
Hetan
The AD9910 seems to have an I2C interface by default, usable with the Wire library.
The AD9910 Have SPI , but i dont known how programing !
You can use the SPI library. You transfer a command byte, then read or write the required number of bytes for that command.
How can i send a 32 bits word through SPI ?
Do 4 transfers:
digitalWrite (ssPin, LOW);
SPI.transfer (byte0);
SPI.transfer (byte1);
SPI.transfer (byte2);
SPI.transfer (byte3);
digitalWrite (ssPin, HIGH);
or
SPI.transfer (dataArray[0]);
SPI.transfer (dataArray[1]);
SPI.transfer (dataArray[2]);
SPI.transfer (dataArray[3]);
or use other methods to break up an unsigned or signed long,
or ...
But 4 transfers no matter what.
Hetan97:
#define SPI_MOSI_PIN MOSI
#define SPI_MISO_PIN MISO
#define SPI_SCK_PIN SCK
#define DDS_CS SS
#define MASTER_RESET 11
#define IO_RESET 6
#define IO_UPDATE 4
SPISettings spiSettings;
#define CFR1 0x00
#define CFR2 0x01
#define CFR3 0x02
static void digitalWriteDirect(int pin, boolean val)
digitalWrite(pin, val);
static inline int digitalReadDirect(int pin)
return digitalRead(pin);
void update()
digitalWriteDirect(IO_UPDATE, LOW);
//Special update used to maximize speed of update
digitalWriteDirect(IO_UPDATE, HIGH);
// if (!fastUpdate)
delayMicroseconds(1);
void set4Wire()
//CFR1 values needed for 4 wire mode
byte set4Wire[4] = {0x00, 0x00, 0x00, 0x02};
resetSPI(); //Reset physical communications (precautionary)
writeReg(CFR1, set4Wire, sizeof(set4Wire)); //Write values to buffer
update(); //Update buffer values into register
void sendWriteAddr(int addr)
SPI.beginTransaction(spiSettings);
digitalWrite(DDS_CS, LOW);
SPI.transfer(addr);
void sendReadAddr(int addr)
SPI.transfer(0x80 | addr);
void writeBytes(byte addr, byte *data, byte length, byte start)
int tmp = 3;
sendWriteAddr(addr);
if (length <= 4)
tmp = len;
for (byte i = start; i < tmp-1; i++)
SPI.transfer(data*);*
  • SPI.transfer(data[length - 1]);*
  • if (length > 4)*
  • //32 bit register length*
  • digitalWrite(DDS_CS, HIGH);*
  • SPI.endTransaction();*
  • writeBytesREndian(data, byte length, 4); //to be test*
    void writeBytesREndian(byte *data, byte length, byte start)
  • for (byte i = start; i > start - (length - 1); i--)*
    _ SPI.transfer(data*);_
    _
    }_
    _
    SPI.transfer(data[start - (length - 1)]); _
    _
    }_
    void readReg(byte addr, byte *data, int length)
    _
    {_
    _
    sendReadAddr(addr);_
    _
    for (byte i = 0; i < length - 1; i++)_
    _
    {_
    _ data = SPI.transfer(0);
    data[length - 1] = SPI.transfer(0);_
    _ SPI.endTransaction();
    void DDSdefaultReset()
    {_
    digitalWrite(MASTER_RESET, HIGH);
    _ delay(100);_
    digitalWrite(MASTER_RESET, LOW);
    _ delay(1);
    void resetSPI()
    {_
    digitalWrite(IO_RESET, HIGH);
    _ delay(10);_
    digitalWrite(IO_RESET, LOW);
    _ delay(1);
    ....._
    pinMode(DDS_CS, OUTPUT);
    pinMode(SPI_MISO_PIN, INPUT);
    pinMode(SPI_MOSI_PIN, OUTPUT);
    pinMode(SPI_SCK_PIN, OUTPUT);
    _ SPI.begin(); //Start SPI on chip select pin for AD9910*
    * spiSettings = SPISettings(40000000UL, MSBFIRST, SPI_MODE0);*
    * DDSdefaultReset();
    set4Wire(); //Function to put AD9910 in wire SPI mode*
    * resetSPI(); //Reset physical communications (precautionary)
    .....*_
