Ada Fruit LED Matrix
I have a system and I can implement an other LED matrix, ADA Fruit one instead of liquid display.
I have the first part that I've created, it's working fine, there's 16 leds, a button that lights up random 8 leds and it's printed the decimal on the lcd, you can turn on or off bits individually.
I want to trying to combine the ADA Fruit LED Matrix, a bigger display instead of this one. Can you help me with any ideas, any bits of code.
#include <Keypad.h>
int out_en = 5;     // Shift-register output enabled, active-low
int rclk = 7;       // Register clock
int srclr = 4;      // Clear shift-register, active-low
int srclk = 6;      // Shift-register clock
int serial_in = A0; // Shift-register data in
unsigned int randomDec;
//// include the library code:
//#include <LiquidCrystal.h>
//// initialize the library with the numbers of the interface pins
//LiquidCrystal lcd(5, 4, 3, 2, 1, 0);
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Four columns
// Define the symbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] ={{'1','2','3','4'},
                            {'5','6','7','8'},
                            {'9','A','B','C'},
                            {'D','E','F','G'}};
byte rowPins[ROWS] = {A1, A2, A3, A4}; // Connect to the row pinouts of the keypad
byte colPins[COLS] = {13, 12, 11, 10}; // Connect to the column pinouts of the keypad
// Initialise an instance of class NewKeypad
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  // set up the LCD's number of columns and rows:
  // lcd.begin(16, 2);
  pinMode(out_en, OUTPUT);
  pinMode(rclk, OUTPUT);
  pinMode(serial_in, OUTPUT);
  pinMode(srclk, OUTPUT);
  pinMode(srclr, OUTPUT);
  //pinMode(buttonPin, INPUT_PULLUP);
  digitalWrite(srclr, LOW);  // Clear shift register, active-low
  digitalWrite(srclr, HIGH);
  // Generate a random number between 0 and 65535
  randomDec= random(65536); // Not random on start-up with 16807 everytime, but this doesn't really matter
  //Serial.print(randomDec);
  //Serial.println();
  showLED();
  //showMATRIX();
  char key = customKeypad.getKey();
  if (key)
    int keyVal = key-'0';
    if (keyVal>=17) keyVal-=7; // keyVal is an integer from 1 to 16 depending on which button is struck
    bool invBit=!bitRead(randomDec,(keyVal-1)); // Read the state of the bit to be inverted
    bitWrite(randomDec, (keyVal-1), invBit);    // Invert the bit
    showLED();
    //showLCD();
    //lcd.clear();
    //lcd.print(keyVal);
void showLED()
  digitalWrite(out_en, HIGH); // Disable output (this is G' (output enabled) on the TPIC6B595 datasheet, active-low)
  digitalWrite(srclk, LOW);   // Required for rising-edge clocked devices
  shiftOut(serial_in, srclk, MSBFIRST, randomDec >> 8);
  shiftOut(serial_in, srclk, MSBFIRST, randomDec);
  digitalWrite(rclk, HIGH);  // Pulse register clock, active-high
  digitalWrite(rclk, LOW);
  digitalWrite(out_en, LOW); // Enable output
//void showLCD()
//  lcd.clear();
//  lcd.setCursor(5, 1);
//  lcd.print(randomDec);
/// Why so complicated?
//unsigned int randomNumber()
//  int index[8] = {-1,-1,-1,-1,-1,-1,-1,-1}; //store the led that will turn on
//  int count = 0;
//  bool isRepeat = false;
//  while(count < 8)
//    int number = random(16);
//    isRepeat = false;
//    for (int i = 0; i < 8; i++){
//      if(number == index[i]) isRepeat = true;
//    if(!isRepeat){
//      index[count] = number;
//      count++;
//  unsigned int decNumber = 0;
//  for(int i = 0; i < 8; i++)
//    bitSet(decNumber,index[i]);
//  return decNumber;
and here's ada code:
//  main.cpp
//  AdaFruit
//  Created by Cojan Flaviu on 28.06.2022.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
 #define PSTR // Make Arduino Due happy
#endif
#define PIN 6
// MATRIX DECLARATION:
// Parameter 1 = width of the matrix
// Parameter 2 = height of the matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
//   NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
//     Position of the FIRST LED in the matrix; pick two, e.g.
//     NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
//   NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
//     rows or in vertical columns, respectively; pick one or the other.
//   NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
//     in the same order, or alternate lines reverse direction; pick one.
//   See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_GRBW    Pixels are wired for GRBW bitstream (RGB+W NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, PIN,
  NEO_MATRIX_TOP     + NEO_MATRIX_LEFT +
  NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG,
  NEO_GRB            + NEO_KHZ800);
const uint16_t colors[] = {
  matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(255);
  matrix.setTextColor(colors[0]);
int x    = matrix.width();
int pass = 0;
  matrix.fillScreen(0);
  matrix.setCursor(x, 0);
  matrix.print(F("Hello"));
  if(--x < -36) {
    x = matrix.width();
    if(++pass >= 3) pass = 0;
    matrix.setTextColor(colors[pass]);
  matrix.show();
  delay(100);
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project.
Sorry and thank you!
