Adabox002 "error: 'digitalPinToPCICR' was not declared in this scope"
Looking for guidance on the following error I'm receiving whenever I try to upload the code to the Feather Bluetooth LE Mini Robot. Using MacOS.
exit status 1 Error compiling for board Arduino Robot Motor.
error: 'digitalPinToPCICRbit' was not declared in this scope *digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
I've taken the code directly from that provide on the website - https://learn.adafruit.com/adabox002/code-for-your-robot
Thanks
x_Natalie_x: Looking for guidance on the following error I'm receiving whenever I try to upload the code to the Feather Bluetooth LE Mini Robot. Using MacOS.
Thanks
Post the full error message in code tags.
(deleted)
Which board do you have selected under Tools>Board?
Arduino Robot Motor is not the correct board to select to use your Feather Bluetooth LE Mini Robot. Please follow these instructions: https://learn.adafruit.com/adafruit-feather-32u4-bluefruit-le/setup
pert: Arduino Robot Motor is not the correct board to select to use your Feather Bluetooth LE Mini Robot. Please follow these instructions: https://learn.adafruit.com/adafruit-feather-32u4-bluefruit-le/setup
Have followed your instructions and I now believe I have the correct board selected, but a new error message.
'avrdude: butterfly_recv(): programmer is not responding'
Managed to fix it... I think it was just a case of pressing reset quickly after upload.
Thanks for all your help re. installing libraries which board to select.
