Today came an IR sensor - TSOP38238 - and I installed the IRRemote library 2.2.3 of shiffer.
Worked very well but I noticed the following:
When I put a finger near the sensor (< 1cm) it suddenly spits out codes. I doubt my fingers transmit a 38KHz signal but I can imagine that the sensor picks up heat and just tries to make the best of it.
If the finger moves closer to the sensor there are more "succesfull" reads. A black SD card behaved similar. White and transparent objects gave less responses.
So another explanation is that the sensor has a 38KHz signal internally for reference and if an object is very close it sees the reflection of that signal.
In the end this effect can be used as a very close proximity sensor (to investigate)
Has anyone seen this behavior before? and can explain it?
