Adafruit 16-Channel PWM & Tower Pro SG90s dying
I'm using two Adafruit 16-channel PWM/servo shields with 26 tower pro sg90 micro servos, and I've had multiple servos die in what seems like a very short timeframe.
The first round of dead servos was after a week of continual sweeping, running 24/7. Inspecting the servos didn't reveal any stripped gears; when I first unplugged them they were slightly warm to the touch.
I replaced the 9 or so that died, calibrated the pulse width for each of them individually to avoid hard stops, and set them all at 90 degrees. (I've got SERVOMIN at around 200 & SERVOMAX at around 650 for each) They have been holding that position for a week, powered 24 hrs/day, only moving for about 30 seconds when I test them briefly every few days by sweeping between 75 and 115 degrees and then setting them back to 90. About 6 or 7 have failed so far.
They're not moving much of a load at all, all of the weight they are moving is supported primarily by traxxas u-joints.
I'm planning on buying a Futaba micro servo to test under the same conditions, assuming that at least part of the problem is that the sg90s were the cheapest option; but it would be really helpful to have some insight from anyone with more servo experience in case there's something I'm doing wrong that are causing these to fail. Or is this just to be expected of servos that are powered and holding position for ~200 hours?
I'm happy to provide more info on my wiring & code if that's helpful. Thanks!
Hobby servos are not designed for 24/7 use, they are not robust precision engineered
components. If you want high reliability and 24/7 use you need something designed for
industrial use.
