How do I change the spi pins of this Shield from 13 12 11 ??
Library:
https://github.com/adafruit/Adafruit_ILI9341/archive/master.zip
Library:
From the header file:
Adafruit_ILI9341(int8_t _CS, int8_t _DC, int8_t _MOSI, int8_t _SCLK,
int8_t _RST, int8_t _MISO);
Adafruit_ILI9341(int8_t _CS, int8_t _DC, int8_t _RST = -1);
So you would use the first form of constructor if you want to bit-bash.
You use the second form when you use the hardware SPI.
David.
"How do I change the spi pins of this Shield from 13 12 11 ?? "
Why, do you want your updates to be slower? The SPI hardware is the fastest way to send serial data out to devices, at clock speeds up to 8 MHz. Anything else will be slower.
