Hi everyone. I'm new to Arduino and have a question that I'm hoping someone can help with.
I am writing a countdown timer using the adafruit 7 segment Display w/I2C Backpack.
I have the code working so that when I press the start button it will start the countdown and when I press the pause button it will pause the counter. I can reset the timer by wiring a button to the reset input on my UNO.
Where I'm struggling is I have assigned 5 outputs (8-12) that will trigger during various points of the countdown. They are being triggered for 5 seconds but when they are triggered the countdown stops and then resumes where it stopped from when the output turns off.
I would like the countdown to continue while the output is on.
My code is below. This is my first post so please let me know if you need more information. Thanks in advance.
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_7segment matrix = Adafruit_7segment();
//Number of seconds to start with
int seconds = 00;
//Number of minutes to start with
int minutes = 02;
int num = 0;
//Starts the countdown timer
int startButton = 1;
//Pauses the countdown timer
int pauseButton = 4;
//Beeps during button presses
int speaker = 6;
int buttonPresses = 0;
long time = 0;
pinMode(startButton, INPUT);
pinMode(pauseButton, INPUT);
pinMode(speaker, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
digitalWrite(startButton, HIGH);
digitalWrite(pauseButton, HIGH);
matrix.begin(0x70);
//Set brightness (Dimmest = 0 Brightest = 15)
matrix.setBrightness (15);
beforeTime();
if (digitalRead(startButton) == LOW) {
beep();
time = millis();
digitalWrite(7, HIGH);
buttonPresses = 1;
if (digitalRead(pauseButton) == LOW) {
beep();
time = millis();
buttonPresses = 2;
switch (buttonPresses) {
case 1:
UpdateTime();
timeRun();
case 2:
timePause();
default:
beforeTime();
time = millis();
void beforeTime() {
matrix.print(10000, DEC); //Print "----" on display
matrix.writeDisplay();
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(12, LOW);
void timeRun() {
num = minutes * 100 + seconds;
matrix.print(num);
//Draw the colon
matrix.drawColon(true);
if (seconds + minutes == 0) {
digitalWrite(12, HIGH);
delay(5000);
buttonPresses = 0;
beforeTime();
//Set time for 1st output trigger
if (minutes == 1 && seconds == 30) {
//Turn the output on by making the voltage HIGH
digitalWrite(8, HIGH);
//Wait for 5 seconds
delay (5000);
//Turn the power off by making the voltage LOW
//Set time for 2nd output trigger
if (minutes == 1 && seconds == 0) {
digitalWrite(9, HIGH);
delay (5000);
//Set time for 3rd output trigger
if (minutes == 0 && seconds == 30) {
digitalWrite(10, HIGH);
delay (5000);
//Set time for 4th output trigger
if (minutes == 0 && seconds == 10) {
digitalWrite(11, HIGH);
delay (5000);
UpdateTime();
void timePause() {
time = millis();
void UpdateTime() {
if ((millis() - time) >= 1000) {
seconds--;
time = millis();
if (seconds == -1) {
minutes--;
seconds = 59;
void beep() {
digitalWrite(speaker, HIGH);
delay(100);
digitalWrite(speaker, LOW);
