Any one have trouble with matrix that won’t start program or liven up unles uno is restarted or re-downloaded
trouble
trouble
If the answer is "Yes", how would that help You?
Please read and use this link: How to get the best out of this forum - Development Tools / IDE 1.x - Arduino Forum
Usually power supply, then wiring.
Hi, just trying to ascertain if this is a common fault so yes would confirm.
Thanks
Neil
Is what a common fault? You gave no useful information. GIGO.
I've been around on this forum a while and I've not heard of this, so I guess not. Have you tried the Adafruit forum?
I think I've sorted it thank you, they seem very sensitive and don't like dupont connectors so changed to xh. Vibration I recon!
Neil Hanrahan 07754656201
Everything is sensitive to Dupont connectors, because Dupont connectors are so unreliable! I'm sure the original ones made by Dupont were better, but everyone uses the cheap Chinese-made ones these days.
DuPont probably use copper female pins and copper wire, and are very reliable as any copper, female pin.
The cheap knockoffs use copper coated steel or copper coated aluminum. Both a breading ground for galvanic corrosion.
