Adafruit and Giga Display Not Working
I have a code that uses the adafruit libraries with the giga r1 and display shield. The code compiles and uploads fine but the screen is blank. I have tried using the examples and most don't do anything to the screen. The only example I have gotten to work was the one that displayed the arduino logo. Has anyone experienced this before and if so, how did you fix it? The code I have looks perfect on paper but it just won't display properly.
You might have better luck getting responses in the forum:
Hardware/Giga Display Shield
I noticed it as I had cleared all new messages and then by chance saw this one.
Yes I have had luck with the GIGA display and the Adafruit GFX code, for example their demo example works fine on mine:
#include "Arduino_GigaDisplay_GFX.h"
GigaDisplay_GFX tft;
#define GC9A01A_CYAN    0x07FF
#define GC9A01A_RED     0xf800
#define GC9A01A_BLUE    0x001F
#define GC9A01A_GREEN   0x07E0
#define GC9A01A_MAGENTA 0xF81F
#define GC9A01A_WHITE   0xffff
#define GC9A01A_BLACK   0x0000
#define GC9A01A_YELLOW  0xFFE0
  Serial.println("GC9A01A Test!");
  tft.begin();
  Serial.println(F("Benchmark                Time (microseconds)"));
  delay(10);
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(GC9A01A_CYAN));
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(GC9A01A_RED, GC9A01A_BLUE));
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(GC9A01A_GREEN));
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(GC9A01A_YELLOW, GC9A01A_MAGENTA));
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, GC9A01A_MAGENTA));
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, GC9A01A_WHITE));
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  Serial.println(F("Done!"));
void loop(void) {
  for (uint8_t rotation = 0; rotation < 4; rotation++) {
    tft.setRotation(rotation);
    testText();
unsigned long testFillScreen() {
  unsigned long start = micros();
  tft.fillScreen(GC9A01A_BLACK);
  yield();
  tft.fillScreen(GC9A01A_RED);
  yield();
  tft.fillScreen(GC9A01A_GREEN);
  yield();
  tft.fillScreen(GC9A01A_BLUE);
  yield();
  yield();
  return micros() - start;
unsigned long testText() {
  tft.setCursor(0, 0);
  tft.setTextColor(GC9A01A_WHITE);  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(GC9A01A_YELLOW); tft.setTextSize(2);
  tft.println(1234.56);
  tft.setTextColor(GC9A01A_RED);    tft.setTextSize(3);
  tft.println(0xDEADBEEF, HEX);
  tft.println();
  tft.setTextColor(GC9A01A_GREEN);
  tft.setTextSize(5);
  tft.println("Groop");
  tft.setTextSize(2);
  tft.println("I implore thee,");
  tft.setTextSize(1);
  tft.println("my foonting turlingdromes.");
  tft.println("And hooptiously drangle me");
  tft.println("with crinkly bindlewurdles,");
  tft.println("Or I will rend thee");
  tft.println("in the gobberwarts");
  tft.println("with my blurglecruncheon,");
  tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = tft.width(),
                h = tft.height();
  yield();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for (x2 = 0; x2 < w; x2 += 6) tft.drawLine(x1, y1, x2, y2, color);
  x2    = w - 1;
  for (y2 = 0; y2 < h; y2 += 6) tft.drawLine(x1, y1, x2, y2, color);
  t     = micros() - start; // fillScreen doesn't count against timing
  yield();
  yield();
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  yield();
  yield();
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  yield();
  yield();
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
  yield();
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = tft.width(), h = tft.height();
  start = micros();
  for (y = 0; y < h; y += 5) tft.drawFastHLine(0, y, w, color1);
  for (x = 0; x < w; x += 5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = tft.width()  / 2,
                cy = tft.height() / 2;
  n     = min(tft.width(), tft.height());
  start = micros();
  for (i = 2; i < n; i += 6) {
    i2 = i / 2;
    tft.drawRect(cx - i2, cy - i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = tft.width()  / 2 - 1,
                cy = tft.height() / 2 - 1;
  for (i = n; i > 0; i -= 6) {
    i2    = i / 2;
    start = micros();
    tft.fillRect(cx - i2, cy - i2, i, i, color1);
    // Outlines are not included in timing results
    tft.drawRect(cx - i2, cy - i2, i, i, color2);
    yield();
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
  start = micros();
  for (x = radius; x < w; x += r2) {
    for (y = radius; y < h; y += r2) {
      tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                      w = tft.width()  + radius,
                      h = tft.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for (x = 0; x < w; x += r2) {
    for (y = 0; y < h; y += r2) {
      tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = tft.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for (i = 0; i < n; i += 5) {
    tft.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      tft.color565(i, i, i));
unsigned long testFilledTriangles() {
  int           i, cx = tft.width()  / 2 - 1,
  start = micros();
  for (i = min(cx, cy); i > 10; i -= 5) {
    start = micros();
    tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                     tft.color565(0, i * 10, i * 10));
    tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                     tft.color565(i * 10, i * 10, 0));
    yield();
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(tft.width(), tft.height());
  start = micros();
  for (i = 0; i < w; i += 6) {
    i2 = i / 2;
    tft.drawRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for (i = min(tft.width(), tft.height()); i > 20; i -= 6) {
    i2 = i / 2;
    tft.fillRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(0, i, 0));
    yield();
Although have run into some bugs where it does not update the actual display with some of the graphic primitives.
I opened up a PR back in February:
fillScreen: trigger a redraw of the screen by KurtE · Pull Request #3 · arduino-libraries/Arduino_GigaDisplay_GFX (github.com)
But so far it has not been merged.
I am pretty sure that it has not been fixed by other commits to the library, as the last commit was last year.
If you are still having issues, you may want to post some code that hopefully builds that demonstrates the issue.
Good luck
