Adafruit - Arduino Ethernet Code for MKR1000
This code works for the Arduino Ethernet, but I can not get it to work on the MKR1000.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <Dns.h>
#include <Dhcp.h>
#include "DHT.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
float h;
float t;
long previousMillis = 0;
#define DHTPIN A0
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
/************************* Ethernet Client Setup *****************************/
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0xE1, 0x46};
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "user_adafruit"
#define AIO_KEY         "key_code"
/************ Global State (you don't need to change this!) ******************/
//Set up the ethernet client
EthernetClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1);  }
/****************************** Feeds ***************************************/
Adafruit_MQTT_Publish Temperatura = Adafruit_MQTT_Publish(&mqtt,  AIO_USERNAME "/feeds/dht11.temperatura");
Adafruit_MQTT_Publish Humidade = Adafruit_MQTT_Publish(&mqtt,  AIO_USERNAME "/feeds/dht11.humidade");
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/arduinoethernet.chave");
/*************************** Sketch Code ************************************/
  Serial.println(F("Start MQTT Sketch"));
  // Initialise the Client
  Serial.print(F("\nInit the Client..."));
  Ethernet.begin(mac);
  delay(1000); //give the ethernet a second to initialize
  mqtt.subscribe(&onoffbutton);
uint32_t x = 0;
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(1000))) {
    if (subscription == &onoffbutton) {
      Serial.print(F("Got: "));
      Serial.println((char *)onoffbutton.lastread);
  unsigned long currentMillis = millis();    //Tempo atual em ms
  if (currentMillis - previousMillis > 15000) {
    publicar();
    previousMillis = currentMillis;    // Salva o tempo atual
  // ping the server to keep the mqtt connection alive
  if (! mqtt.ping()) {
    mqtt.disconnect();
  sensor();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
void sensor() {
  h = dht.readHumidity();
  t = dht.readTemperature();
  if (isnan(t) || isnan(h))
    Serial.println("Failed to read from DHT");
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
  // delay(100);
void publicar() {
  // Now we can publish stuff!
  Serial.print(F("\nSending Temperatura val "));
  Serial.print(t);
  Serial.print("...");
  if (! Temperatura.publish(t)) {
    Serial.println(F("Failed"));
    Serial.println(F("OK!"));
  Serial.print(F("\nSending Humidade val "));
  Serial.print(h);
  if (! Humidade.publish(h)) {
The code I’m working on is this.
#include <SPI.h>
#include <WiFi101.h>
#include "DHT.h"
#include <Dns.h>
#include <Dhcp.h>
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
float h;
float t;
#define DHTPIN A0
  dht.begin();
  while (!Serial) {
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while (true);
  Serial.print ("WiFi.status = " );
  if (WiFi.status() != WL_NO_SHIELD) {
    conectar();
    MQTT_connect();
  printCurrentNet();
  sensor();
  delay(10000);
void conectar()
  while ( WiFi.status() != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    WiFi.begin(ssid, pass);
  Serial.print("You're connected to the network");
  printCurrentNet();
  printWiFiData();
void printWiFiData() {
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
void sensor() {
    Serial.print(h);
    Serial.print(t);
  // delay(100);
void publicar() {
  Serial.print(t);
  Serial.print(h);
  int8_t ret;
    return;
    mqtt.disconnect();
The error message is:
Connection failed
Retrying MQTT connection in 5 seconds…
Connection failed
Connection failed
I’m not properly using the wifi libraries in conjunction with the Adafruit libraries.
I've already found the solution, you have to change the EthernetClient client line; by the WiFiClient client;
