Disclaimer: New to BLE so apologies if my questions sound foolish, but would really appreciate some tips
-I am using the Adafruit Bluefruit nRF52832 board w/ mac
-I have successfully added the board in 'board manager' and updated the bootloader, as advised by Adafruit. All that works great
-My goal: connect to computer via Bluetooth and send data from board to computer and read via serial monitor.
-I successfully connected using LightBlue BLE app and the connection shows up in my toolbar, as well as ports in IDE.
From forums and youtube, it looks like I should be able to use the "Serial.print" function to print to serial via Bluetooth, given that everything else is connected properly. Am I missing something?
Here is an example of one of the sketches I am using to test, from the Adafruit Bluefruit nRF52832 library-
#include <bluefruit.h>
// OTA DFU service
BLEDfu bledfu;
// Peripheral uart service
BLEUart bleuart;
// Central uart client
BLEClientUart clientUart;
while ( !Serial ) delay(10); // for nrf52840 with native usb
Serial.println("Bluefruit52 Dual Role BLEUART Example");
Serial.println("-------------------------------------\n");
// Initialize Bluefruit with max concurrent connections as Peripheral = 1, Central = 1
// SRAM usage required by SoftDevice will increase with number of connections
Bluefruit.begin(1, 1);
Bluefruit.setTxPower(4); // Check bluefruit.h for supported values
Bluefruit.setName("Bluefruit52 duo");
// Callbacks for Peripheral
Bluefruit.Periph.setConnectCallback(prph_connect_callback);
Bluefruit.Periph.setDisconnectCallback(prph_disconnect_callback);
// Callbacks for Central
Bluefruit.Central.setConnectCallback(cent_connect_callback);
Bluefruit.Central.setDisconnectCallback(cent_disconnect_callback);
// To be consistent OTA DFU should be added first if it exists
bledfu.begin();
// Configure and Start BLE Uart Service
bleuart.begin();
bleuart.setRxCallback(prph_bleuart_rx_callback);
// Init BLE Central Uart Serivce
clientUart.begin();
clientUart.setRxCallback(cent_bleuart_rx_callback);
/* Start Central Scanning
- Enable auto scan if disconnected
- Interval = 100 ms, window = 80 ms
- Filter only accept bleuart service
- Don't use active scan
- Start(timeout) with timeout = 0 will scan forever (until connected)
Bluefruit.Scanner.setRxCallback(scan_callback);
Bluefruit.Scanner.restartOnDisconnect(true);
Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms
Bluefruit.Scanner.filterUuid(bleuart.uuid);
Bluefruit.Scanner.useActiveScan(false);
Bluefruit.Scanner.start(0); // 0 = Don't stop scanning after n seconds
// Set up and start advertising
startAdv();
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
// Include bleuart 128-bit uuid
Bluefruit.Advertising.addService(bleuart);
// Secondary Scan Response packet (optional)
// Since there is no room for 'Name' in Advertising packet
Bluefruit.ScanResponse.addName();
/* Start Advertising
- Enable auto advertising if disconnected
- Interval: fast mode = 20 ms, slow mode = 152.5 ms
- Timeout for fast mode is 30 seconds
- Start(timeout) with timeout = 0 will advertise forever (until connected)
- For recommended advertising interval
Technical Q&A QA1931: Using the correct Bluetooth LE Advertising and Connection Parameters for a stable connection
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
// do nothing, all the work is done in callback
/* Peripheral
void prph_connect_callback(uint16_t conn_handle)
// Get the reference to current connection
BLEConnection* connection = Bluefruit.Connection(conn_handle);
char peer_name[32] = { 0 };
connection->getPeerName(peer_name, sizeof(peer_name));
Serial.print("[Prph] Connected to ");
Serial.println(peer_name);
void prph_disconnect_callback(uint16_t conn_handle, uint8_t reason)
(void) conn_handle;
(void) reason;
Serial.println("[Prph] Disconnected");
void prph_bleuart_rx_callback(uint16_t conn_handle)
(void) conn_handle;
// Forward data from Mobile to our peripheral
char str[20+1] = { 0 };
bleuart.read(str, 20);
Serial.print("[Prph] RX: ");
Serial.println(str);
if ( clientUart.discovered() )
clientUart.print(str);
}else
bleuart.println("[Prph] Central role not connected");
/* Central
void scan_callback(ble_gap_evt_adv_report_t* report)
// Since we configure the scanner with filterUuid()
// Scan callback only invoked for device with bleuart service advertised
// Connect to the device with bleuart service in advertising packet
Bluefruit.Central.connect(report);
void cent_connect_callback(uint16_t conn_handle)
Serial.print("[Cent] Connected to ");
Serial.println(peer_name);;
if ( clientUart.discover(conn_handle) )
// Enable TXD's notify
clientUart.enableTXD();
}else
// disconnect since we couldn't find bleuart service
Bluefruit.disconnect(conn_handle);
void cent_disconnect_callback(uint16_t conn_handle, uint8_t reason)
(void) conn_handle;
(void) reason;
Serial.println("[Cent] Disconnected");
- Callback invoked when uart received data
- @param cent_uart Reference object to the service where the data
- arrived. In this example it is clientUart
void cent_bleuart_rx_callback(BLEClientUart& cent_uart)
cent_uart.read(str, 20);
Serial.print("[Cent] RX: ");
if ( bleuart.notifyEnabled() )
// Forward data from our peripheral to Mobile
bleuart.print( str );
}else
// response with no prph message
clientUart.println("[Cent] Peripheral role not connected");
