I am using the Adafruit CC3000 wifi shield with the Arduino Mega 2560 R3 to access a remote webserver. The code reads 16 values provided by a php file and then moves on. The values are float but read as char and then converted on Arduino. Most times, the connection and data read are successful. Within a several minutes (it varies), however, the code hangs up AFTER successfully reading ALL values. At this point I have to reset. I've tried putting timers on that section of the code, but everything hangs so the timers don't function.
I have just updated the firmware to the TI CC3000; it is currently version 1.28. I'm also using the latest Adafruit CC3000 library downloaded from here: GitHub - adafruit/Adafruit_CC3000_Library: Library code for Adafruit's CC3000 WiFi breakouts &c. The updates have not changed the outcome.
It seems to me either the client.read() or client.available() function is hanging up, but I have relative little experience with programming to dig into the libraries much.
Here's the Arduino code:
#include <Adafruit_CC3000.h>
#include <SPI.h>
#define WLAN_SSID "xxxxxxx"
#define WLAN_PASS "xxxxxxx"
#define WLAN_SECURITY WLAN_SEC_WPA2
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIV2);
String repository = "/gromon/";
uint32_t ip = cc3000.IP2U32(xxx,xxx,xxx,xxx);
int port = 80;
void setup(void)
if (!cc3000.begin())
Serial.println("Can't initiate wifi board...");
while(1);
if(!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY))
Serial.println("Can't connect to WiFi AP!");
Serial.println("Connected to WiFi AP...");
Serial.println(F("Check DHCP..."));
while (!cc3000.checkDHCP())
delay(100);
void loop(void)
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, port);
char thresholdsettings[16][4];
if (client.connected())
client.print("GET ");
client.print(repository);
client.print("readenvironparams.php?");
client.println(" HTTP/1.1");
client.println("Host: www.example.com");
client.println(F(""));
Serial.println(" Connected to readenvironparams.php. Awaiting data...");
Serial.println(F(" Connection failed"));
while (client.connected())
while (client.available() > 0)
char c = client.read();
if(c == '>')
Serial.print(c);
for (int i = 0; i < 17; i++)
for(int q = 0; q < 5; q++)
c = client.read();
if(c == '!')
q=5;
thresholdsettings[i][q] = c;
Serial.print(thresholdsettings[i][q]);
Serial.print(" ");
} //The failure happens about here just after successfully reading the last value provided by the PHP file.
Serial.print(c);
client.println("Connection: close");
client.close();
delay(30000);
This is the PHP file being used:
<?php
$link = include('conec.php');
$tblname = 'environparams';
$result = mysqli_query($link, "SELECT * FROM $tblname");
if (!$result) {
echo "Failed to access db";
exit;
$row = mysqli_fetch_array($result);
echo ">" . $row['tempFthresholdlow'] . "!";
echo $row['tempFthresholdhigh'] . "!";
echo $row['humiditythresholdlow'] . "!";
echo $row['humiditythresholdhigh'] . "!";
echo $row['phthresholdlow'] . "!";
echo $row['phthresholdhigh'] . "!";
echo $row['nutrientsthresholdlow'] . "!";
echo $row['nutrientsthresholdhigh'] . "!";
echo $row['h2olevelthresholdlow'] . "!";
echo $row['h2olevelthresholdhigh'] . "!";
echo $row['co2thresholdlow'] . "!";
echo $row['co2thresholdhigh'] . "!";
echo $row['dissolvedo2thresholdlow'] . "!";
echo $row['dissolvedo2thresholdhigh'] . "!";
echo $row['temph2othresholdlow'] . "!";
echo $row['temph2othresholdhigh'] . "!";
//close mysql connection
mysqli_close($link);
Here is the Serial output from the code above. The first entry is a success (reads through to value "85" and then prints "0"); the second is the failure (it reads to expected value "85", prints nothing more and completely hangs.
HTTP/1.1 200 OK
Date: Thu, 18 Sep 2014 20:24:57 GMT
Server: Apache
Vary: Accept-Encoding
Transfer-Encoding: chunked
Content-Type: text/html
3a
50 200 20 95 6.2 7.4 10 40 10.5 14 600 1500 50 100 50 85
0
HTTP/1.1 200 OK
Date: Thu, 18 Sep 2014 20:25:24 GMT
Server: Apache
Content-Length: 58
Has anyone else run into this? Any ideas/solutions, elegant or otherwise?
A tremendous thanks for your time in advance!
