Adafruit cc3000 - issue with blink LED
Arduino UNO
Adafruit cc3000 Wifi shield Firmware-1.24
I did not see similar question.
I want to make wifi controlled led, turn on/off from anywhere in the world using Internet. For this reason I made website and "state.php" page that contains numbers "0" or "1". I used a standard Adafruit cc3000 WebClient Library to connect "state.php" page. At the end of the code in "while (www.connected())" loop I added if condition for controll led.
Generally speaking the goal is reached but...
I noticed when "state.php" content is "1" LED lights with periodic blinking.
I guess it happens during the passage through the loop code, but do not know to solve it.
Also, after a while, WiFi Shield stops working and I can not control LED over the Internet.
I don't know why this is happening. Can someone help.
Below is my code.
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID       "MyWLANSSID"           // cannot be longer than 32 characters!
#define WLAN_PASS       "MyWLANPASS"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS  6000
#define WEBSITE      "www.mywebsite.com"
#define WEBPAGE      "/state.php"
uint32_t ip;
int lednum = 7;
  pinMode(lednum, OUTPUT);
     /* Initialise the module */
    Serial.println(F("Initializing..."));
    if (!cc3000.begin())
      Serial.println(F("Couldn't begin()! Check your wiring?"));
      while(1);
          /* Delete any old connection data on the module */
          Serial.println(F("Deleting old connection profiles"));
          if (!cc3000.deleteProfiles()) {
            Serial.println(F("Failed!"));
            while(1);
              Serial.print(F("Attempting to connect..."));
              //Serial.println(WLAN_SSID);
              if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
                while(1);
              Serial.println(F("\nConnected!"));
                   // Try looking up the website's IP address
                   ip = 0;
                   while (ip == 0) {
                    if (! cc3000.getHostByName(WEBSITE, &ip)) {
                      Serial.println(F("Couldn't resolve!"));
        /* Try connecting to the website.
        Note: HTTP/1.1 protocol is used to keep the server from closing the connection before all data is read.
        Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
        if (www.connected()) {
          www.fastrprint(F("GET "));
          www.fastrprint(WEBPAGE);
          www.fastrprint(F(" HTTP/1.1\r\n"));
          www.fastrprint(F("Host: "));
          www.fastrprint(WEBSITE);
          www.fastrprint(F("\r\n"));
          www.println();
          Serial.println(F("Connection failed"));
          return;
        /* Read data until either the connection is closed, or the idle timeout is reached. */
        String data;
        data = String("");
        unsigned long lastRead = millis();
            while (www.available())
            char c = www.read();
            data += c;
        data.trim();
        int lenght = data.length();
        String sign = data.substring(lenght-4, lenght-3);
        int b = atoi(sign.c_str());
        Serial.println(b);
            if(b==1){
             digitalWrite(lednum, HIGH);
            if(b==0){
             digitalWrite(lednum, LOW);
After you get a disconnect message from the server, you must call www.stop().
              data += c;
           data.trim();
           Serial.println(b);
            if(b==1){
            if(b==0){
// add this call
        www.stop();
But that may not be your only problem. It appears you could be running out of SRAM also. Many servers return more than the SRAM can handle.
I added "www.stop ()" as you suggested.
But unfortunately, the LED is still blinking.
I noticed on the serial monitor during the loop a certain number of "0".
Precisely 17 "0", although it should be all "1".
Are you aware the response from the server may come in more than one packet? The "while(www.available())" loop reads only one of the packets.
I didn't know and what is the solution of problems.
Is the solution optimization SRAM?
