Adafruit CC33000 Library WebClient Local PHP
Hello,
I'm attempting to retrieve some phps from my new Adafruit CC3000 Library using the Webclient example and it works fine for all "internet" sites but I can't seem to get it to work for my local server.
Here is my Arduino Code:
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ   3  // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,SPI_CLOCK_DIVIDER);
#define WLAN_SSID       "MikroTik"
#define WLAN_PASS       "7409721385"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
//#define WEBSITE "http://192.168.88.240"
//#define WEBPAGE "/Home_Automation/checkStatus.php?DeviceCount=3&Type=Toggles&Device0=HVAC_Fan&Device1=HVAC_Ac&Device2=HVAC_Heat"
#define WEBSITE      "192.168.88.240"
#define WEBPAGE      "/home_automation/test.php"
#define IDLE_TIMEOUT_MS  3000      // Amount of time to wait (in milliseconds) with no data
                                   // received before closing the connection.  If you know the server
                                   // you're accessing is quick to respond, you can reduce this value.
uint32_t ip = cc3000.IP2U32(192, 168, 88, 240);
  Serial.begin(57600);
  CC3000_setup();
  WebRequest();
void CC3000_setup()
  Serial.println(F("Hello, CC3000!\n"));
  displayDriverMode();
  Serial.print("Free RAM: "); Serial.println(getFreeRam(), DEC);
  /* Initialise the module */
  Serial.println(F("\nInitialising the CC3000 ..."));
  if (!cc3000.begin())
    Serial.println(F("Unable to initialise the CC3000! Check your wiring?"));
    while(1);
  uint16_t firmware = checkFirmwareVersion();
  if ((firmware != 0x113) && (firmware != 0x118)) {
    Serial.println(F("Wrong firmware version!"));
    for(;;);
  displayMACAddress();
  /* Delete any old connection data on the module */
  Serial.println(F("\nDeleting old connection profiles"));
  if (!cc3000.deleteProfiles()) {
    Serial.println(F("Failed!"));
    while(1);
  /* Attempt to connect to an access point */
  char *ssid = WLAN_SSID;             /* Max 32 chars */
  Serial.print(F("\nAttempting to connect to ")); Serial.println(ssid);
  /* NOTE: Secure connections are not available in 'Tiny' mode! */
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    while(1);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
    @brief  Displays the driver mode (tiny of normal), and the buffer
            size if tiny mode is not being used
    @note   The buffer size and driver mode are defined in cc3000_common.h
void displayDriverMode(void)
  #ifdef CC3000_TINY_DRIVER
    Serial.println(F("CC3000 is configure in 'Tiny' mode"));
  #else
    Serial.print(F("RX Buffer : "));
    Serial.print(CC3000_RX_BUFFER_SIZE);
    Serial.println(F(" bytes"));
    Serial.print(F("TX Buffer : "));
    Serial.print(CC3000_TX_BUFFER_SIZE);
  #endif
    @brief  Tries to read the CC3000's internal firmware patch ID
uint16_t checkFirmwareVersion(void)
  uint8_t major, minor;
  uint16_t version;
#ifndef CC3000_TINY_DRIVER
  if(!cc3000.getFirmwareVersion(&major, &minor))
    Serial.println(F("Unable to retrieve the firmware version!\r\n"));
    version = 0;
    Serial.print(F("Firmware V. : "));
    Serial.print(major); Serial.print(F(".")); Serial.println(minor);
    version = major; version <<= 8; version |= minor;
#endif
  return version;
    @brief  Tries to read the 6-byte MAC address of the CC3000 module
void displayMACAddress(void)
  uint8_t macAddress[6];
  if(!cc3000.getMacAddress(macAddress))
    Serial.println(F("Unable to retrieve MAC Address!\r\n"));
    Serial.print(F("MAC Address : "));
    cc3000.printHex((byte*)&macAddress, 6);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
    @brief  Begins an SSID scan and prints out all the visible networks
void listSSIDResults(void)
  uint8_t valid, rssi, sec, index;
  char ssidname[33];
  index = cc3000.startSSIDscan();
  Serial.print(F("Networks found: ")); Serial.println(index);
  Serial.println(F("================================================"));
  while (index) {
    index--;
    valid = cc3000.getNextSSID(&rssi, &sec, ssidname);
    Serial.print(F("SSID Name    : ")); Serial.print(ssidname);
    Serial.print(F("RSSI         : "));
    Serial.println(rssi);
    Serial.print(F("Security Mode: "));
    Serial.println(sec);
  cc3000.stopSSIDscan();
void WebRequest()
  Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
  if (www.connected()) {
    www.fastrprint(F("GET "));
    www.fastrprint(WEBPAGE);
    www.fastrprint(F(" HTTP/1.1\r\n"));
    www.fastrprint(F("Host: ")); www.fastrprint(WEBSITE); www.fastrprint(F("\r\n"));
    www.println();
    Serial.println(F("Connection failed"));
    return;
  Serial.println(F("-------------------------------------"));
  /* Read data until either the connection is closed, or the idle timeout is reached. */
  unsigned long lastRead = millis();
  while (www.connected() && (millis() - lastRead < IDLE_TIMEOUT_MS)) {
    while (www.available()) {
      char c = www.read();
      Serial.print(c);
  www.close();
  /* You need to make sure to clean up after yourself or the CC3000 can freak out */
  /* the next time your try to connect ... */
  Serial.println(F("\n\nDisconnecting"));
  cc3000.disconnect();
My HTML code:
My output is the following:
Hello, CC3000!
RX Buffer : 131 bytes
TX Buffer : 131 bytes
Free RAM: 6697
Firmware V. : 1.24
MAC Address : 0x08 0x00 0x28 0x59 0x25 0x15
Attempting to connect to MikroTik
Started AP/SSID scan
Connecting to MikroTik...Waiting to connect...Connected!
Request DHCP
IP Addr: 192.168.88.209
Netmask: 255.255.255.0
Gateway: 192.168.88.1
DHCPsrv: 192.168.88.1
DNSserv: 192.168.88.1
Connect to 192.168.88.240:80
Disconnecting
This is really annoying me and I can't figure out why it's not working, please help!! :smiley:
The http:// is missing in one of the below.
good catch, but when i fixed that, same results
