Hello,
I was working with some code on my home computer and without plugging in the actual board the code works fine and does not produce any errors, however, when I plug in the board to upload code the Arduino IDE asks to download additional libraries to deal with the board, after this happens I get an error from one of the libraries I am using (PulseSensorPlayground.h) saying that it cannot find <#include "SAMDTimerInterrupt.h"/>
I cannot find any information online about this specific error, besides trying to install the SAMD Timer Interrupt (did not work). For some additional info, although I do not think the issue is with my code, I will paste it below. I am trying to make a heartbeat monitor that also reports when it detects a spike or drop in HR, then alerts the user and displays a message.
#define PULSE_SENSOR_PIN A3
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
#include <Adafruit_CircuitPlayground.h>
//#include <SPI.h>
LiquidCrystal_I2C lcd(0x27,16,2); // Makes the LCD
int pulseValue;
int WarningThreshold = 30;
int Threshold = 550;
unsigned long lastBeatTime = 0;
int BPM;
int BPMChange = 0;
int previousBPM = -1;
int BPamp;
unsigned long startTime = 0;
const int PulseWire = 3; // PulseSensor RED WIRE connected to ANALOG PIN 3
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
int xdata; int ydata; int zdata;
Serial.begin(9600); // For Serial Monitor
CircuitPlayground.begin();
lcd.init();
lcd.backlight();
startTime = millis();
pulseSensor.analogInput(PulseWire);
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("Start Data");
lcd.setCursor(0,0);
lcd.print("Welcome To");
lcd.setCursor(0,1);
lcd.print("POTS Portable");
else {
lcd.setCursor(0,0);
lcd.print("Error"); //This prints one time at Arduino power-up, or on Arduino reset.
void Alert() {
for (int i = 0; i < 3; i++) { // Beep 3 times
CircuitPlayground.playTone(440, 500); // 440 Hz for 500 ms
delay(200); // Small pause between beeps
void Flash() {
for (int i = 0; i < 3; i++) { // Flash 3 times
CircuitPlayground.setPixelColor(0, 255, 0, 0); // Set all LEDs to red
delay(200);
CircuitPlayground.clearPixels(); // Turn off LEDs
delay(200);
void GetAccelData() {
xdata = CircuitPlayground.motionX();
ydata = CircuitPlayground.motionY();
zdata = CircuitPlayground.motionZ();
//continuous window
//HEART RATE DISPLAY and HR CHANGE
int BPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
Serial.print("BPM:"); // Print phrase "BPM: "
Serial.println(BPM);
lcd.setCursor(0,0);
lcd.print("BPM:");
lcd.setCursor(8,0);
lcd.print(" "); // Clear previous BPM
lcd.setCursor(8,0);
lcd.print(BPM);
pulseSensor.blinkOnPulse(LED13); // added now not sure if works
if(previousBPM >= 0 ){
float BPMChange = abs(previousBPM-BPM);
Serial.print("Difference: ");
Serial.print(BPMChange);
if (BPMChange > WarningThreshold) { // This whole thing just basically says that if the change is greater than the threshold, display a warning on the LCD, flash and make a sound, then store all that data in the Serial file
Serial.println("A POTS Event may be Occuring");
lcd.setCursor(0,0);
lcd.print(" POTS ");
lcd.setCursor(0,1);
lcd.print(" Event Occuring");
// Panic
Alert();
Flash();
// Acceleration Data recording
GetAccelData(); // Gets the acceleration data
Serial.print("X : "); // Prints acceleration data to serial file
Serial.print(xdata);
Serial.print("Y : ");
Serial.print(ydata);
Serial.print("Z : ");
Serial.print(zdata);
// Blood pressure reading (needs to be calibrated, right now this just returns the amplitude of the wave (peak - trough))
BPamp = pulseSensor.getPulseAmplitude();
Serial.print("BP Amp : ");
Serial.print(BPamp);
previousBPM = BPM; // make the current BPM -> Old, then start over again
lastBeatTime = millis();
//Serial.print("Light Sensor Value: ");
//Serial.println(lightValue);
delay(20);
