ME: New to Arduino and coding in general & it shows because I can't compile an example.
Board: Martrixportal S3
I have the libraries loaded. It imports them. When I read through the output it appears to me, the error is generating from code inside the library. I say this because, the line of code with the error does not match the line of code in the sketch. See output below
OUTPUT:
FQBN: esp32:esp32:adafruit_matrixportal_esp32s3
Using board 'adafruit_matrixportal_esp32s3' from platform in folder: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
Using core 'esp32' from platform in folder: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
cmd /c if exist "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\partitions.csv" COPY /y "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\partitions.csv" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\partitions.csv"
cmd /c if not exist "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\partitions.csv" if exist "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3\\partitions.csv" COPY "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3\\partitions.csv" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\partitions.csv"
cmd /c if not exist "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\partitions.csv" COPY "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\tools\\partitions\\tinyuf2-partitions-8MB.csv" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\bootloader.bin" ( COPY /y "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\bootloader.bin" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\pixeldust.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3\\bootloader-tinyuf2.bin" ( COPY "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3\\bootloader-tinyuf2.bin" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\pixeldust.ino.bootloader.bin" ) ELSE ( "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 8MB -o "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\pixeldust.ino.bootloader.bin" "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
1 file(s) copied.
cmd /c if exist "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\build_opt.h" COPY /y "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust\\build_opt.h" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\build_opt.h"
cmd /c if not exist "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\build_opt.h" type nul > "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\build_opt.h"
cmd /c type nul > "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4/file_opts"
Detecting libraries used...
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Wire.h: [Wire@3.0.4]
ResolveLibrary(Wire.h)
-> candidates: [Wire@3.0.4]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_LIS3DH.h: [Adafruit LIS3DH@1.3.0]
ResolveLibrary(Adafruit_LIS3DH.h)
-> candidates: [Adafruit LIS3DH@1.3.0]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for SPI.h: [SPI@3.0.4]
ResolveLibrary(SPI.h)
-> candidates: [SPI@3.0.4]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_BusIO_Register.h: [Adafruit BusIO@1.16.1]
ResolveLibrary(Adafruit_BusIO_Register.h)
-> candidates: [Adafruit BusIO@1.16.1]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_Sensor.h: [Adafruit Unified Sensor@1.1.14]
ResolveLibrary(Adafruit_Sensor.h)
-> candidates: [Adafruit Unified Sensor@1.1.14]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_PixelDust.h: [Adafruit PixelDust@1.1.3]
ResolveLibrary(Adafruit_PixelDust.h)
-> candidates: [Adafruit PixelDust@1.1.3]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_Protomatter.h: [Adafruit Protomatter@1.6.1]
ResolveLibrary(Adafruit_Protomatter.h)
-> candidates: [Adafruit Protomatter@1.6.1]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Alternatives for Adafruit_GFX.h: [Adafruit GFX Library@1.11.10]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit GFX Library@1.11.10]
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH\Adafruit_LIS3DH.cpp
Using cached library dependencies for file: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust\Adafruit_PixelDust.cpp
Using cached library dependencies for file: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\Adafruit_Protomatter.cpp
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\core.c -o nul
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp -o nul
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp -o nul
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp -o nul
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c -o nul
Generating function prototypes...
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp-xs3\2302/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ADAFRUIT_MATRIXPORTAL_ESP32S3" -DARDUINO_VARIANT="adafruit_matrixportal_esp32s3" -DARDUINO_PARTITION_tinyuf2-partitions-8MB -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/defines -IC:\Users\pfoelker\AppData\Local\Temp\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\pixeldust -iprefix C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/include/ @C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/flags/includes -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32s3/qio_qspi/include -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\adafruit_matrixportal_esp32s3 -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH -IC:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src -IC:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/build_opt.h @C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4/file_opts C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\sketch\pixeldust.ino.cpp -o C:\Users\pfoelker\AppData\Local\Temp\2146694570\sketch_merged.cpp
C:\Users\pfoelker\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\pfoelker\AppData\Local\Temp\2146694570\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-xs3\\2302/bin/xtensa-esp32s3-elf-g++" -MMD -c "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/cpp_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ADAFRUIT_MATRIXPORTAL_ESP32S3\"" "-DARDUINO_VARIANT=\"adafruit_matrixportal_esp32s3\"" -DARDUINO_PARTITION_tinyuf2-partitions-8MB "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/defines" "-IC:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust" -iprefix "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/include/" "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/includes" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/qio_qspi/include" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\cores\\esp32" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\libraries\\Wire\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_LIS3DH" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\libraries\\SPI\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_Unified_Sensor" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_PixelDust" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_Protomatter\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "@C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4/build_opt.h" "@C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4/file_opts" "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\sketch\\pixeldust.ino.cpp" -o "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\sketch\\pixeldust.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Wire\Wire.cpp.o
Compiling library "Adafruit LIS3DH"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_LIS3DH\Adafruit_LIS3DH.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit BusIO"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling library "Adafruit Unified Sensor"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_Unified_Sensor\Adafruit_Sensor.cpp.o
Compiling library "Adafruit PixelDust"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_PixelDust\Adafruit_PixelDust.cpp.o
Compiling library "Adafruit Protomatter"
"C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-xs3\\2302/bin/xtensa-esp32s3-elf-gcc" -MMD -c "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/c_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ADAFRUIT_MATRIXPORTAL_ESP32S3 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ADAFRUIT_MATRIXPORTAL_ESP32S3\"" "-DARDUINO_VARIANT=\"adafruit_matrixportal_esp32s3\"" -DARDUINO_PARTITION_tinyuf2-partitions-8MB "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:adafruit_matrixportal_esp32s3:UploadSpeed=921600,USBMode=default,CDCOnBoot=cdc,MSCOnBoot=default,DFUOnBoot=default,UploadMode=cdc,CPUFreq=240,FlashMode=qio,FlashSize=8M,PartitionScheme=tinyuf2,DebugLevel=none,PSRAM=enabled,LoopCore=1,EventsCore=1,EraseFlash=none,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/defines" "-IC:\\Users\\pfoelker\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2024811-20592-1fd340v.glw5\\pixeldust" -iprefix "C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/include/" "@C:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/flags/includes" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32s3/qio_qspi/include" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\cores\\esp32" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\adafruit_matrixportal_esp32s3" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\libraries\\Wire\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_LIS3DH" "-IC:\\Users\\pfoelker\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\libraries\\SPI\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_Unified_Sensor" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_PixelDust" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_Protomatter\\src" "-IC:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "@C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4/build_opt.h" "@C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4/file_opts" "C:\\Users\\pfoelker\\Documents\\Arduino\\libraries\\Adafruit_Protomatter\\src\\core.c" -o "C:\\Users\\pfoelker\\AppData\\Local\\Temp\\arduino\\sketches\\86822A461EF5F673D7B974E3AD5774A4\\libraries\\Adafruit_Protomatter\\core.c.o"
Using previously compiled file: C:\Users\pfoelker\AppData\Local\Temp\arduino\sketches\86822A461EF5F673D7B974E3AD5774A4\libraries\Adafruit_Protomatter\Adafruit_Protomatter.cpp.o
In file included from C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\arch/arch.h:190,
from C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\core.c:33:
C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\arch/esp32-common.h: In function '_PM_esp32commonTimerInit':
C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\arch/esp32-common.h:92:19: error: too many arguments to function 'timerBegin'
92 | core->timer = timerBegin(_PM_timerNum, 2, true); // 1:2 prescale, count up
In file included from C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32/esp32-hal.h:84,
from C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32/Arduino.h:36,
from C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\arch/arch.h:166:
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32/esp32-hal-timer.h:35:13: note: declared here
35 | hw_timer_t *timerBegin(uint32_t frequency);
C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter\src\arch/esp32-common.h:94:3: error: too many arguments to function 'timerAttachInterrupt'
94 | timerAttachInterrupt(timer, &_PM_esp32timerCallback, true);
C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32/esp32-hal-timer.h:50:6: note: declared here
50 | void timerAttachInterrupt(hw_timer_t *timer, void (*userFunc)(void));
Using library Wire at version 3.0.4 in folder: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\Wire
Using library Adafruit LIS3DH at version 1.3.0 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_LIS3DH
Using library SPI at version 3.0.4 in folder: C:\Users\pfoelker\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\SPI
Using library Adafruit BusIO at version 1.16.1 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_BusIO
Using library Adafruit Unified Sensor at version 1.1.14 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Unified_Sensor
Using library Adafruit PixelDust at version 1.1.3 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_PixelDust
Using library Adafruit Protomatter at version 1.6.1 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_Protomatter
Using library Adafruit GFX Library at version 1.11.10 in folder: C:\Users\pfoelker\Documents\Arduino\libraries\Adafruit_GFX_Library
exit status 1
Compilation error: exit status 1
