I am trying to operate adafruit feather m0 on deepsleep mode and wake after time interrupt. I use arduino low power library. The microcontroller is suppsoed to consume only 300uA in deepsleep but i can achieve only 2.7 mA. If i put all pins to low, it goes down to 1.3mA but nothing less. Has anyone tried deepsleep in this board. Any help is appreciated.
pinMode(LED_BUILTIN, OUTPUT);
// Uncomment this function if you wish to attach function dummy when RTC wakes up the chip
LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, dummy, CHANGE);
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
// Triggers a 20000 ms sleep (the device will be woken up only by the registered wakeup sources and by internal RTC)
// The power consumption of the chip will drop consistently
LowPower.deepSleep(20000);
void dummy() {
int i = 10;
