This is the example from adafruit that prints the hex of the fingerprint template. Currently, this is what I'm referencing at.
printHex() is what prints the hex code, and downloadFingerPrintTemplate() retrieves the template.
#include <Adafruit_Fingerprint.h>
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
int getFingerprintIDez();
while (!Serial);
Serial.println("Fingerprint template extractor");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
// Try to get the templates for fingers 1 through 10
for (int finger = 1; finger < 10; finger++) {
downloadFingerprintTemplate(finger);
uint8_t downloadFingerprintTemplate(uint16_t id)
Serial.println("------------------------------------");
Serial.print("Attempting to load #"); Serial.println(id);
uint8_t p = finger.loadModel(id);
switch (p) {
case FINGERPRINT_OK:
Serial.print("Template "); Serial.print(id); Serial.println(" loaded");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
default:
Serial.print("Unknown error "); Serial.println(p);
return p;
// OK success!
Serial.print("Attempting to get #"); Serial.println(id);
p = finger.getModel();
switch (p) {
Serial.print("Template "); Serial.print(id); Serial.println(" transferring:");
default:
return p;
// one data packet is 267 bytes. in one data packet, 11 bytes are 'usesless' :D
uint8_t bytesReceived[534]; // 2 data packets
memset(bytesReceived, 0xff, 534);
uint32_t starttime = millis();
int i = 0;
while (i < 534 && (millis() - starttime) < 20000) {
if (mySerial.available()) {
bytesReceived[i++] = mySerial.read();
Serial.print(i); Serial.println(" bytes read.");
Serial.println("Decoding packet...");
uint8_t fingerTemplate[512]; // the real template
memset(fingerTemplate, 0xff, 512);
// filtering only the data packets
int uindx = 9, index = 0;
memcpy(fingerTemplate + index, bytesReceived + uindx, 256); // first 256 bytes
uindx += 256; // skip data
uindx += 2; // skip checksum
uindx += 9; // skip next header
index += 256; // advance pointer
memcpy(fingerTemplate + index, bytesReceived + uindx, 256); // second 256 bytes
for (int i = 0; i < 512; ++i) {
//Serial.print("0x");
printHex(fingerTemplate[i], 2);
//Serial.print(", ");
Serial.println("\ndone.");
return p;
uint8_t templateBuffer[256];
memset(templateBuffer, 0xff, 256); //zero out template buffer
int index=0;
while ((index < 256) && ((millis() - starttime) < 1000))
templateBuffer[index] = mySerial.read();
index++;
Serial.print(index); Serial.println(" bytes read");
//dump entire templateBuffer. This prints out 16 lines of 16 bytes
for (int count= 0; count < 16; count++)
for (int i = 0; i < 16; i++)
Serial.print("0x");
Serial.print(templateBuffer[count*16+i], HEX);
Serial.print(", ");
void printHex(int num, int precision) {
char tmp[16];
char format[128];
sprintf(format, "%%.%dX", precision);
sprintf(tmp, format, num);
Serial.print(tmp);
I am using Arduino UNO R3, RX and TX pins of the sensor are at the 2 & 3 digital pins.
I have this as my current sketch, which is pretty empty.
int fingerprintPresence = 0;
while(fingerprintPresence == 0){
//TODO: Change the message to number code
Serial.println("Fingerprint sensor present");
fingerprintPresence = 1;
void printHex(int num) {
char tmp[16];
char format[128];
sprintf(format, "%%.%dX", 1);
Serial.print(tmp);
