Adafruit Flow meter 828 Liters/min
Hello ,
I am new to arduino community and i would like to know how can i program adafruit flow meter http://www.adafruit.com/products/828 .
I want to measure the liters/min so that i know the speed of water in a pipe . From GitHub i found the code which count the total liters passing through the sensor . Does anyone has the code for measuring Q(liters/min) continuously ??
Thank you in advance !! :slight_smile:
Surely if the code you have tells you the total quantity that must be between two instants in time? (eg perhaps t0= when the sketch started, and t1= now.) I surmise (since you didn't post the code) that it keeps a total of the quantity which grows each time through loop().
You could use millis() to attach a time to each go through loop(), then you can subtract the 2x millis'es to give you a time between each quantity measurements, and hence get the flow as quantity/time.
Something like that anyway, but post the code for better help.
This is the code from GitHub :
This is example code for using the Adafruit liquid flow meters.
Tested and works great with the Adafruit plastic and brass meters
    ------> http://www.adafruit.com/products/828
    ------> http://www.adafruit.com/products/833
Connect the red wire to +5V,
the black wire to common ground
and the yellow sensor wire to pin #2
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above must be included in any redistribution
#include "LiquidCrystal.h"
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// which pin to use for reading the sensor? can use any pin!
#define FLOWSENSORPIN 2
// count how many pulses!
volatile uint16_t pulses = 0;
// track the state of the pulse pin
volatile uint8_t lastflowpinstate;
// you can try to keep time of how long it is between pulses
volatile uint32_t lastflowratetimer = 0;
// and use that to calculate a flow rate
volatile float flowrate;
// Interrupt is called once a millisecond, looks for any pulses from the sensor!
SIGNAL(TIMER0_COMPA_vect) {
  uint8_t x = digitalRead(FLOWSENSORPIN);
  if (x == lastflowpinstate) {
    lastflowratetimer++;
    return; // nothing changed!
  if (x == HIGH) {
    //low to high transition!
    pulses++;
  lastflowpinstate = x;
  flowrate = 1000.0;
  flowrate /= lastflowratetimer;  // in hertz
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
   Serial.print("Flow sensor test!");
   lcd.begin(16, 2);
   pinMode(FLOWSENSORPIN, INPUT);
   digitalWrite(FLOWSENSORPIN, HIGH);
   lastflowpinstate = digitalRead(FLOWSENSORPIN);
   useInterrupt(true);
void loop()                     // run over and over again
  lcd.setCursor(0, 0);
  lcd.print("Pulses:"); lcd.print(pulses, DEC);
  lcd.print(" Hz:");
  lcd.print(flowrate);
  //lcd.print(flowrate);
  Serial.print("Freq: "); Serial.println(flowrate);
  Serial.print("Pulses: "); Serial.println(pulses, DEC);
  // if a plastic sensor use the following calculation
  // Sensor Frequency (Hz) = 7.5 * Q (Liters/min)
  // Liters = Q * time elapsed (seconds) / 60 (seconds/minute)
  // Liters = (Frequency (Pulses/second) / 7.5) * time elapsed (seconds) / 60
  // Liters = Pulses / (7.5 * 60)
  float liters = pulses;
  liters /= 7.5;
  liters /= 60.0;
  // if a brass sensor use the following calculation
  liters /= 8.1;
  liters -= 6;
  liters /= 60.0;
  Serial.print(liters); Serial.println(" Liters");
  lcd.setCursor(0, 1);
  lcd.print(liters); lcd.print(" Liters        ");
  delay(100);
Actually i can’t understand this
liters /= 7.5;
liters /= 60.0;
What does the liters/=60.0; means ?
I will be grateful if you can help :slight_smile: !
Adafruit_FlowMeter.pde (58.4 KB)
liters /= 60.0; Is a compound statement, means the same as liters = liters / 60.0;
Oh I see !! Thank you !!
So i thought that it would be easier to set a code to see if i have a flow or not ! So i came up with that :
#define FLOWSENSORPIN 3
int pulsecounter = 0;
int test=1;
    while (test = 1){
      pulsecounter= digitalRead(FLOWSENSORPIN);
   if (pulsecounter == LOW){
    Serial.print("We have flow");
    Serial.print('\n');
     delay(100);
    else if (pulsecounter == HIGH ){
      Serial.print("We DONT have flow");
      Serial.print('\n');
    delay(100);
Is it ok ? I have some trouble though because the sensor changes state very easily only by picking him up!
Any suggestions what may cause that ?
Thank you in advance!
