adafruit fps - id issues
I have faced fps sensor problems. it takes the fingerprints correctly with arduino uno but during verifying, it always returns to id#0 with only last fingerprint that I entered. Rest of fingerprints are not counted. I followed the same steps in the tutorial.
here is the enroll code
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t getFingerprintEnroll(int id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  Serial.println("fingertest");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1);
void loop()                     // run over and over again
  Serial.println("Type in the ID # you want to save this finger as...");
  int id = 0;
  while (true) {
    while (! Serial.available());
    char c = Serial.read();
    if (! isdigit(c)) break;
    id *= 10;
    id += c - '0';
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (!  getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(int id) {
  int p = -1;
  Serial.println("Waiting for valid finger to enroll");
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  Serial.print("ID "); Serial.println(id);
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
