Hello,
I try to use the library Adafruit-GFX-Library in order to use the TFT 2.2 Inch LCD device, but I always have this error message:
Arduino : 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Users\COCALE~1\AppData\Local\Temp\ccr6Lj1q.ltrans0.ltrans.o: In function `main':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `setup'
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Here, the sketch (Part of Adafruit-GFX-Library/graphictest exemple):
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// For the Adafruit shield, these are the default.
#define TFT_RESET 8
#define TFT_DC 9
#define TFT_CS 10
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RESET);
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
How can I fix it please ?
PS: I am using:
- Arduino IDE 1.8.7
- Arduino Uno card
- cf. screenshot for connection (do not know how ton integrate image here)
