#include <LibPrintf.h>
#include <RF24.h>
#include <RF24Network.h>
#include <SPI.h>
RF24 radio(48, 53);// nRF24L01 (CE,CSN)
RF24Network network(radio);
const uint16_t this_node = 00; // Address of our node in Octal format ( 04,031, etc)
# define TestPin 49
int var = 0;
String The_Last = "-------";
String B_Last = "-------";
String BB_Last = "-------";
String BBB_Last = "-------";
String BBBB_Last = "-------";
String BBBBB_Last = "-------";
float AVG_CUT, AVG_MFG, PARTS_MADE;
String AVG_CUT_STR, AVG_MFG_STR, PARTS_MADE_STR, MSG_STR ;
String MACH_ID;
String PeriodMillis_STR;
int PeriodMillis;
long TR_SEQ = 1; // Transmission sequence, transmission id.
//////////////////////////TFT
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
//#include <Fonts/FreeSansBold24pt7b.h>
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// Serial.print("TFT size is "); Serial.print(tft.width()); Serial.print("x"); Serial.println(tft.height());
uint16_t identifier = tft.readID();
if (identifier == 0x9325) {
// Serial.print(F("Unknown LCD driver chip: "));
// Serial.println(identifier, HEX);
identifier = 0x9341;
tft.begin(identifier);
// testFillScreen();
tft.setRotation(1); //0 is portrait , 1 is lanscape, 2 portrait upside down, 3 is lanscape reversed
tft.setCursor(1, 1);
//tft.println();
tft.fillScreen(BLACK);
tft.setCursor(10, 110);
//tft.println();
tft.setTextColor(GREEN);
tft.setTextSize(4);
tft.print("AWAITING SIGNAL ");
SPI.begin();
radio.begin();
if (!radio.begin()) {
Serial.println(F("radio hardware is not responding!!"));
while (1) {} // hold in infinite loop
{ Serial.println ("Radio OK");
network.begin(90, this_node); //(channel, node address)
// network.begin(80, this_node); //(channel, node address)
radio.setPALevel(RF24_PA_MAX);
radio.setDataRate(RF24_2MBPS);
pinMode(TestPin, INPUT_PULLUP);
Serial.print("This node is OK : ");
Serial.println(this_node);
//tft.setTextColor(YELLOW);
//tft.setTextSize(4);
//tft.setCursor(10, 10);
//tft.print("NODE OK:");
tft.setCursor(290, 10);
tft.print(this_node);
tft.setCursor(0, 210);
//tft.println();
tft.setTextSize(2.5);
tft.println("Data Collector by Machine-Cycle.US");
tft.println("");
tft.print("Ver. INFINITY_Receiver_02 - APR 2021");
delay (2000);
tft.setTextSize(4);
tft.print("RECEIVED:");
///////////////////Test section
if (digitalRead (TestPin) == 0) // button is pushed
// tft.print(IncStrR1);
tft.print("TEST OUTPUT");
String Mach_ID [32] = {"1", "2", "3" , "4", "5" , "6", "7", "8", "9"};
for (int i = 0; i <= 10; i++) {
String TestOut = Mach_ID [i] + " " + (i + 10) + " " + "3" + " " + "OPR" + " " + "INFO" + " ";
Serial.println(TestOut);
delay(10);
if (i = 10)
{ The_Last = "-------";
B_Last = "-------";
}// end for loop
tft.print("AWAITING SIGNAL");
} // end test
network.update();
while ( network.available() ) {
RF24NetworkHeader header;
char text[32] = "";
network.read(header, &text, sizeof(text)); // Read the incoming data
String End = "End";
The_Last = text; //+End; // converting the Char array to string c.
//The_Last = The_Last.substring(0, The_Last.length() - 1);
Serial.println(The_Last);
tft.fillRect(0, 60, 480, 300, BLUE);
tft.setTextSize(4);
tft.setCursor(10, 70);
tft.print (The_Last);
tft.print (B_Last);
tft.setCursor(10, 150);
tft.print (BB_Last);
tft.setCursor(10, 190);
tft.print (BBB_Last);
tft.setCursor(10, 230);
tft.print (BBBB_Last);
tft.setCursor(10, 270);
tft.print (BBBBB_Last);
BBBBB_Last = BBBB_Last;
BBBB_Last = BBB_Last;
BBB_Last = BB_Last;
BB_Last = B_Last;
B_Last = The_Last;
} // end of else
