adafruit ili9341 libary and utouch
hello
i want to use utouch with the ili9341 libary from adafruit but it looks like it is not realy good calibrated becouse if i create a simple drawing program that gets the x and y from the tft and then place a pixel on that place it is just drawed not on the place i pressed but ca 10 pixels less!!
code for drawing program:
#include <UTouch.h>
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
int color = ILI9341_GREEN;
#define TFT_DC 9
#define TFT_CS 10
UTouch        myTouch(6,5,4,3,2);
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
int x, y;
  x = 0;
  y = 0;
  tft.begin();
  tft.setRotation(1);
 tft.fillScreen(ILI9341_BLACK);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_EXTREME);
  srl = Serial.read();
    if (myTouch.dataAvailable())
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      if (x != 1)
      //tft.fillCircle(x,y,4,color);
      tft.drawPixel(x,y,collor);
      Serial.print("x= ");
      Serial.print(x);
      Serial.print("   y= ");
      Serial.print(y);
      Serial.println("   ");
     x = 0;
     y = 0;
when i draw something and go to a corner it says 309 x 232 and when i go further it is outside the touch area.
so the maximum a can press is 309 x 232 and then need to calibrate it.
the thing i tried was draw a + on the screen and i need to press it.
it is placed on 150 x 150 but the screen says 141 x 143 when i press it.
so i did
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      cal_x = 150 - x;
      cal_y = 150 - y;
      x = 0;
      y = 0;
and then every time i want the x and the y i do:
      myTouch.read();
      x=myTouch.getX();
      y=myTouch.getY();
      x += cal_x;
      y += cal_y;
and when i press on x 150 and y 150 with a pencil it works!
but when i press for example on the top it does not work.
so i need to calibrate another way.
but i dont know another ways.
so how can i make a calibration thing with the adafruit ili9341 lib and utouch lib?
thanks everyone
Have you used the UTouch_Calibration sketch to get CAL_X, CAL_Y and CAL_S for your display? If not then run that sketch, calibrate and update the values in UTouchCD.h.
but the problem is that i dont know how to connect it for utft.
it works now for adafruit.
and i cant find much for wiring.
can i use hardware spi?
and for the peaple who think that in my code i change the cal_x and cal_y from utouchcd.h the answer is no.
i didnt know they where also called the same as i did.
so i dont change them of utouchcd.h but of the self declaird ints.
You can maybe try my ILI9341_due library, I also have UTouchCalibration sketch in the examples folder.
