Adafruit_ImageReader + SD card files
I am trying to display a .bmp file on my 2.0 TFT SPI display. I have followed all the tutorials on displaying images and i can get all of them to work just fine. The problem is that the .bmp file i am trying to display is not on the root of the SD card but instead within a folder. I have tried using the reader.drawBMP() methods by suppling the path & filename but no image is rendered. Any help would be apprecaited. For context, the image is located at /001/image.bmp. Code below:
#include <Adafruit_GFX.h>         // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SdFat.h>                // SD card & FAT filesystem library
#include <Adafruit_ImageReader.h> // Image-reading functions
// TFT display and SD card share the hardware SPI interface, using
// 'select' pins for each to identify the active device on the bus.
#define SD_CS    4 // SD card select pin
#define TFT_CS  10 // TFT select pin
#define TFT_DC   8 // TFT display/command pin
#define TFT_RST  9 // Or set to -1 and connect to Arduino RESET pin
#define BUFFPIXEL 20
SdFat                SD;         // SD card filesystem
Adafruit_ImageReader reader(SD); // Image-reader object, pass in SD filesys
Adafruit_ST7789      tft    = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
  ImageReturnCode stat;
  #if !defined(ESP32)
    while (!Serial);
  #endif
  tft.init(240, 320);           // Init ST7789 320x240
  tft.setRotation(1);
  tft.setTextWrap(true);
  tft.fillScreen(ST77XX_WHITE);
  Serial.print(F("Initializing filesystem..."));
  // SD card is pretty straightforward, a single call...
  if (!SD.begin(SD_CS)) {
    Serial.println(F("SD begin() failed"));
    return;
//Add a border to the display:
//tft.drawRoundRect(2,2,316,236,4,ST77XX_RED);
//tft.drawRoundRect(4,4,312,232,4,ST77XX_RED);
//Draw the image:
reader.drawBMP("/001/image.bmp",tft,4,4);
Hi
try to change folder to 001 before reading the file:
