Adafruit LED Matrix - Bitmaps within Classes
Hi everyone.
I am trying to build a dash for my motorcycle using 8x 8x16 mini LED matrices from Adafruit. [So imagine a display 16 LEDs high, 64 wide]
As part of the project as a whole I would like to display an icon on screen when an input is triggered. [ie press turn signal and an ‘arrow’ icon flashes on screen].
Have got this working with many inputs, but the code is very repetitive so I would like to consolidate this down into a class. I would then instantiate a version with a specific bitmap icon for a given input. However I can’t seem to get it work with a bitmap as one of the arguments.[is that the right term?]
I have tried various versions of the below code with out any luck, but i think it indicates what i am trying to achieve.
Any pointers?
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_LEDBackpack.h>
Adafruit_8x16minimatrix matrix[8] =
 Adafruit_8x16minimatrix(), Adafruit_8x16minimatrix(),
class sensor
  public:
  sensor( int pin, int matrix, int bmp, int cursorX, int cursorY, int width, int height, long checkInt);
  void begin();
  void update();
  private:
  unsigned long _previousMillis;
  unsigned long _currentMillis;
  int _pin;
  int _matrix;
  long _checkInt;
  int _cursorX;
  int _cursorY;
  int _width;
  int _height;
  int _bmp;
  int _state;
  uint8_t _BMP;
sensor::sensor(int pin, int matrix, int bmp, int cursorX, int cursorY, int width, int height, long checkInt)
  _pin = pin;
  _checkInt = checkInt;
  _bmp = bmp;
  _cursorX = cursorX;
  _cursorY = cursorY;
  _width = width;
  _height = height;
  _matrix = matrix;
void sensor::begin()
  pinMode(_pin, INPUT_PULLUP);
void sensor::update()
  _state = digitalRead(_pin);
  if(_bmp == 1)
    static const uint8_t PROGMEM _BMP[]=    // leftBMP
      B00001000,
      B00011000,
      B00110000,
      B01100000,
      B11000000,
      B01100000,
      B00110000,
      B00011000,
      B00001000
  if(_bmp == 2)
    static const uint8_t PROGMEM _BMP[] =   // rightBMP
      B10000000,
      B11000000,
      B01100000,
      B00110000,
      B00011000,
      B00110000,
      B01100000,
      B11000000,
      B10000000
  _previousMillis = 0;
  _currentMillis = millis();
  if(_currentMillis - _previousMillis >= _checkInt)
    if(_state == HIGH)
      matrix[_matrix].drawBitmap(_cursorX, _cursorY, _BMP, _width, _height, LED_OFF);//display 'negative' icon on matrix display - NOTE LED_'OFF'
      matrix[_matrix].writeDisplay();
      matrix[_matrix].drawBitmap(_cursorX, _cursorY, _BMP, _width, _height, LED_ON); //display icon on matrix display
    _previousMillis = millis();
// (pin no, matrix no, bitmap no, cursorX, cursorY, bitmap width, bitmap height, check frequency)
sensor left     (2, 0, 1, 0, 4, 5, 9, 250);
sensor right    (3, 7, 2, 3, 4, 5, 9, 250);
  for (int i = 0; i < 8; i++)
    matrix[i].begin(0x70 + i);
    matrix[i].setRotation(0);
    matrix[i].clear();
    matrix[i].writeDisplay();
  left.begin();
  right.begin();
  left.update();
  right.update();
You want these declarations at top, outside of your code. They define fixed areas of memory containing those patterns. They should have different identifiers like “leftBMP”, “rightBMP”
static const uint8_t PROGMEM leftBMP[]=  {
      B00001000,
      B00011000,
      B00110000,
      B01100000,
      B11000000,
      B01100000,
      B00110000,
      B00011000,
      B00001000
static const uint8_t PROGMEM rightBMP[]= {
      B10000000,
      B11000000,
      B01100000,
      B00110000,
      B00011000,
      B00110000,
      B01100000,
      B11000000,
      B10000000
Have a look at the examples on the PROGMEM reference page and then set up a table to refer to your strings bitmaps.
const char* const bmp_table[] PROGMEM = {leftBMP, rightBMP, and so on...};
You can then select which bitmap with a number (starting at 0) by:
  // remove all this lot:
  // if(_bmp == 1)  etc.   Note that _bmp will now have to be 0 for leftBMP, 1 for rightBMP etc.
  _previousMillis = 0;                                  // <--- what's this being set to zero
  if(_currentMillis - _previousMillis >= _checkInt)       // <--- and then being used here ???
    if(_state == HIGH)
       // output the bitmap selected by '_bmp'
       matrix[_matrix].drawBitmap(_cursorX, _cursorY, bmp_table[_bmp], _width, _height, LED_OFF);
Yours,
TonyWilk
Cheers Tony!
Thanks for your input.
On implementating this I keep getting an error “call of overloaded ‘drawbitmap...’ is ambiguous”.
But I will read through the reference info to try n get my head around where I might be going wrong.
S
I am still not having any luck getting a class parameter into the drawBitmap. function.
I have revised the code…
#include <Wire.h>
static const uint8_t PROGMEM leftBMP[] =
  B00001000,
  B00011000,
  B00110000,
  B01100000,
  B11000000,
  B01100000,
  B00110000,
  B00011000,
  B00001000
static const uint8_t PROGMEM rightBMP[] =
  B10000000,
  B11000000,
  B01100000,
  B00110000,
  B00011000,
  B00110000,
  B01100000,
  B11000000,
  B10000000
const char* const bmp_table[] PROGMEM = {leftBMP, rightBMP};
class sensor
  public:
  void begin();
  void update();
  private:
  int _pin;
  int _matrix;
  long _checkInt;
  int _cursorX;
  int _cursorY;
  int _width;
  int _height;
  int _bmp;
  int _state;
  _pin = pin;
  _bmp = bmp;
  _cursorX = cursorX;
  _cursorY = cursorY;
  _width = width;
  _height = height;
  _matrix = matrix;
    if(_state == HIGH)
      matrix[_matrix].drawBitmap(_cursorX, _cursorY, bmp_table[_bmp], _width, _height, LED_OFF);//display 'negative' icon on matrix display - NOTE LED_'OFF'
      matrix[_matrix].drawBitmap(_cursorX, _cursorY, bmp_table[_bmp], _width, _height, LED_ON); //display icon on matrix display
sensor left     (2, 0, 0, 0, 4, 5, 9, 250);
sensor right    (3, 7, 1, 3, 4, 5, 9, 250);
    matrix[i].setTextWrap(false);
    matrix[i].setBrightness(1);  //set display brightness
    matrix[i].clear();
  left.begin();
  right.begin();
  left.update();
  right.update();
I get the following errors…
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
/Users/Sean/Desktop/temp/temp.ino: In member function 'void sensor::update()':
temp:93: error: call of overloaded 'drawBitmap(int&, int&, const char* const&, int&, int&, int)' is ambiguous
/Users/Sean/Desktop/temp/temp.ino:93:95: note: candidates are:
In file included from /Users/Sean/Desktop/temp/temp.ino:2:0:
/Users/Sean/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.h:67:5: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t) <near match>
     drawBitmap(int16_t x, int16_t y, const uint8_t bitmap[],
/Users/Sean/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.h:67:5: note:   no known conversion for argument 3 from 'const char* const' to 'const uint8_t* {aka const unsigned char*}'
/Users/Sean/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.h:71:5: note: void Adafruit_GFX::drawBitmap(int16_t, int16_t, uint8_t*, int16_t, int16_t, uint16_t) <near match>
     drawBitmap(int16_t x, int16_t y, uint8_t *bitmap,
/Users/Sean/Documents/Arduino/libraries/Adafruit_GFX_Library/Adafruit_GFX.h:71:5: note:   no known conversion for argument 3 from 'const char* const' to 'uint8_t* {aka unsigned char*}'
temp:98: error: call of overloaded 'drawBitmap(int&, int&, const char* const&, int&, int&, int)' is ambiguous
/Users/Sean/Desktop/temp/temp.ino:98:94: note: candidates are:
exit status 1
option enabled in File -> Preferences.
Is this something that needs to be dealt with in the Adafruit_GFX_Library?
Sorry, my mistake...
I hadn't noticed that drawBitmap is defined like this in Adafruit_GFX.h
      int16_t w, int16_t h, uint16_t color),
so this line
should be:
const uint8_t* const bmp_table[] PROGMEM = {leftBMP, rightBMP};
now it compiles for me at least :slight_smile:
Yours,
TonyWilk
Brilliant. You're a legend!
Cheers, Tony.
My only problem now is that the bitmaps do not display as they should. They appear to be quite random and tend to change on each compile. the 'LED_ON' version of the bitmap is also different from the 'LED_OFF' bit maps which usually would cancel each other out.
I don't know what that means...
OK. I don't why this works, but it does...
Instead of this portion of the code outside of the class:
  B00001000,
  B00011000,
  B00110000,
  B01100000,
  B11000000,
  B01100000,
  B00110000,
  B00011000,
  B00001000
  B10000000,
  B11000000,
  B01100000,
  B00110000,
  B00011000,
  B00110000,
  B01100000,
  B11000000,
  B10000000
I moved it inside void sensor::update() & deleted the 'static const ' from the bitmap arrays and 'const' from the table array:
  uint8_t PROGMEM leftBMP[] =  // _bmp = 0
    B00001000,
    B00011000,
    B00110000,
    B01100000,
    B11000000,
    B01100000,
    B00110000,
    B00011000,
    B00001000
  uint8_t PROGMEM rightBMP[] = // _bmp = 1
    B10000000,
    B11000000,
    B01100000,
    B00110000,
    B00011000,
    B00110000,
    B01100000,
    B11000000,
    B10000000
  uint8_t* const PROGMEM bmp_table[]  =
    leftBMP,
    rightBMP
    if(_state == HIGH)
works as expected...
Here is the complete working code for anyone following this…
#include <Wire.h>
class sensor
  public:
  void begin();
  void update();
  private:
  unsigned long _previousMillis = 0;
  int _pin;
  int _matrix;
  long _checkInt;
  int _cursorX;
  int _cursorY;
  int _width;
  int _height;
  int _bmp;
  int _state;
  _pin = pin;
  _bmp = bmp;
  _cursorX = cursorX;
  _cursorY = cursorY;
  _width = width;
  _height = height;
  _matrix = matrix;
    B00001000,
    B00011000,
    B00110000,
    B01100000,
    B11000000,
    B01100000,
    B00110000,
    B00011000,
    B00001000
    B10000000,
    B11000000,
    B01100000,
    B00110000,
    B00011000,
    B00110000,
    B01100000,
    B11000000,
    B10000000
    leftBMP,
    rightBMP
    if(_state == HIGH)
    matrix[i].clear();
  left.begin();
  right.begin();
  left.update();
  right.update();
Well done !
It’s taken me a while to get to the bottom of this one, I think it’s a bit of a compiler bug.
I’ve fixed your earlier version by simply changing:
to:
const uint8_t* const bmp_table[] = {leftBMP, rightBMP};
It seems to only go wrong when you have a member variable of a class used as the index into ‘bmp_table’. And that shouldn’t happen.
Ah… on the PROGMEM reference page it does say:
Notes and Warnings
Please note that variables must be either globally defined, OR defined with the static keyword, in order to work with PROGMEM.
Anyhow… you got it going :slight_smile:
Yours,
TonyWilk
