So I've been looking into how to use an Arduino as a DAQ, the topic has been brought up a number of times by various people this one I personally feel to be the most conclusive. We know from the Analogread reference that the arduino samples from the analog pin at roughly ~9kHz which is awesome. But when you try to store the data by printing it to the serial, sampling drops to about 1kHz at best if not lower. This is because the serial data rate of 115200 baud is just really slow in comparison.
Now with the new Cortex M0 chip and an onboard SD card that is using I2C (I think?) on the Adalogger, one should be able to write analogread to SD at I2C speeds which is faster than the analog sampling rate . Thus you should be able to actually record at the max analog sampling rate of ~9kHz and print it to the SD and then print the SD card contents to serial after the fact for analysis. Or am I missing something?
For my own personal application I'm looking to sample at around 10kHz for maybe 5 seconds but with a big enough SD card, one should be able to sample quite a bit in both resolution and time. Also, would the Cortex M0 have a different analog sample frequency than the 328P?
