I have this code, but the motors stop frequently, almost every 2 seconds. I'm not a programmer, and I just started using Arduino Uno a week ago for this project.
This is the code:
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
#include <AFMotor.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield(); // Crear objeto de Adafruit Motor Shield
AF_DCMotor motor1(1); // Definir motor 1 en el canal 1
AF_DCMotor motor2(2); // Definir motor 2 en el canal 2
Serial.begin(9600); // Iniciar comunicación serial a 9600 bps
AFMS.begin(); // Iniciar la Adafruit Motor Shield
motor1.setSpeed(90); // Establecer velocidad del motor 1 al 90%
motor1.run(FORWARD); // Hacer girar el motor 1 hacia adelante
motor2.setSpeed(90); // Establecer velocidad del motor 2 al 90%
motor2.run(BACKWARD); // Hacer girar el motor 2 hacia atrás
// El loop puede permanecer vacío si no hay ninguna otra acción necesaria
Your motor function calls are inside setup() and only run one time before exiting. Move your motor function calls into loop() and the motor calls will be called continuously.
Thank you for your reply.
I did it again with this code, and I got the same result.
