Adafruit Motor Shield
Hello everyone,i was stuck in a case.I have a motor shield.It has own connectors to put the wire on arduino directly,thats ok.But i wonder that which connector does represent the pins of arduino ? Such as , I connected the wires on M1 part of the shield.But Which pins of arduino does the M1 part represent ? Thank you..
Which shield, can you post a link, when i write adafruit motor shield, it brings various types. Please post some data about board, driver and the thing you try to do. Then we can help as much as we can.
Regards.
Im sorry,i just know there is one type of shield of adafruit :slight_smile: Here is the link . Arduino Playground - AdafruitMotorShield
Thank you again..
M1, M2 etc are the outputs to upto 4 motors. They are not connected to the Arduino, but to the
motor driver chips on the shield. The relevant Arduino control pins for each motor channel
will be given in the "Technical Details" section of Adafruit's website.
the outputs are fed from the drivers, true, but if you look at the silk screen you will see the arduino pin 3 goes (via the driver) to M2, pin 5 to M4 etc.
