ADAFRUIT MUSIC MAKER
Ciao a tutti!
Ho acquistato questo prodotto:
Ora sto cercando di capire lo sketch che ho trovato tra gli esempi di arduino ma non ho la più pallida idea di dove iniziare.
Lo sketch si chiama "player_simple" ed è il seguente:
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  //Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
   if (!SD.begin(CARDCS)) {
    Serial.println(F("SD failed, or not present"));
    while (1);  // don't do anything more
  // list files
  printDirectory(SD.open("/"), 0);
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play one file, don't return until complete
  Serial.println(F("Playing track 001"));
  musicPlayer.playFullFile("track001.mp3");
  // Play another file in the background, REQUIRES interrupts!
  Serial.println(F("Playing track 002"));
  musicPlayer.startPlayingFile("track002.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1);
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  delay(100);
/// File listing helper
void printDirectory(File dir, int numTabs) {
   while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
       //Serial.println("**nomorefiles**");
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');
     Serial.print(entry.name());
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
> roby_sporte: ti ricordo che in conformità al regolamento, punto 7, devi editare il tuo post (quindi NON scrivendo un nuovo post, ma utilizzando il bottone More -> Modify che si trova in basso a destra del tuo post) e racchiudere il codice all'interno dei tag CODE (... sono quelli che in edit inserisce il bottone con icona fatta così: </>, tutto a sinistra).
Grazie,
Guglielmo
gpb01:
Grazie,
Guglielmo
Ciao Guglielmo,
grazie mille per avermelo detto. Ho corretto il mio post e spero di averlo fatto nel modo giusto!
Buona giornata!
