Adafruit NeoPixel 60 Ring Clock Project - Error Message When Compiling Sketch
I am taking my first tentative steps into an Arduino project at 41 and hope that some of the more experienced users can help me:
When I try to compile/upload the sketch I get the following:
Error Message:
Arduino: 1.8.7 (Windows 10), Board: “Arduino Gemma”
C:\Users\Simon\AppData\Local\Temp\arduino_modified_sketch_177552\ds1307.ino: In function ‘void setup()’:
ds1307:10:11: error: ‘Serial’ was not declared in this scope
while (!Serial); // for Leonardo/Micro/Zero
ds1307:12:3: error: ‘Serial’ was not declared in this scope
Serial.begin(57600);
C:\Users\Simon\AppData\Local\Temp\arduino_modified_sketch_177552\ds1307.ino: In function ‘void loop()’:
ds1307:31:5: error: ‘Serial’ was not declared in this scope
Serial.print(now.year(), DEC);
exit status 1
Hardware:
Adafruit Trinket 5V (Adafruit Trinket - Mini Microcontroller - 5V Logic : ID 1501 : $6.95 : Adafruit Industries, Unique & fun DIY electronics and kits)
Adafruit Neo Pixel Ring (NeoPixel 1/4 60 Ring - 5050 RGB LED w/ Integrated Drivers : ID 1768 : $9.95 : Adafruit Industries, Unique & fun DIY electronics and kits)
Tiny RTC i2c module (http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-tiny-rtc-d1307-tutorial/)
Wiring Schematic: (using Tiny RTC instead of Adafruit RTC - wired same way)
Code:
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
void loop () {
    DateTime now = rtc.now();
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(" (");
    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days and 30 seconds into the future
    DateTime future (now + TimeSpan(7,12,30,6));
    Serial.print(" now + 7d + 30s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    delay(3000);
The Trinket does not have a hardware serial port. So you will need to remove all the Serial commands from your code.
This is a bit unfortunate because it's nice to be able to get some debug output. It is probably possible to use a library to add a software serial port but the memory of the Trinket's ATtiny85 microcontroller is extremely limited so you may not have enough room for that.
zeke-zero:
Arduino: 1.8.7 (Windows 10), Board: "Arduino Gemma"
Make sure to select the correct board from the Tools > Board menu. I know the Gemma and Trinket use the same microcontroller, so maybe this will work. I don't have any experience with these boards. There are instructions on the Adafruit site that show you how to add support for the Trinket to the Arduino IDE.
pert:
Why not use the LED pixels themselves as debug output?
First, forget about making the timekeeping work, and just see if you can light up the LED pixels in a pattern of your choice. Once you've done that, then you can use the pixels to display information.
