Hello gents
I copied the colorWipe funktion from the Neopixel strandtest. When i set the color on all rgb (125, 146, 255) the programme crashes and restart again or sometimes its just stuck. However when i only change it to one color (0, 0, 255), it works perfectly. And the rainbow funktion works perfectly too.
It looks like the Arduino cant handle all 3 color in rgb set?
The board that i uses: Arduino Nano
The Code:
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
const int LED_SOLO_PIN = 3;
const int LED_SOLO_BRIGHTNESS = 10;
#define LED_PIN 6
#define LED_COUNT 78
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// setup() function -- runs once at startup --------------------------------
pinMode( LED_PIN, OUTPUT );
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
// END of Trinket-specific code.
strip.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
strip.show(); // Turn OFF all pixels ASAP
strip.setBrightness(30); // Set BRIGHTNESS to about 1/5 (max = 255)
// loop() function -- runs repeatedly as long as board is on ---------------
// Fill along the length of the strip in various colors...
analogWrite( LED_SOLO_PIN, LED_SOLO_BRIGHTNESS );
colorWipe(strip.Color(125, 255, 255), 40); // Red
colorWipe(strip.Color(125, 160, 255), 40); // Green
// Some functions of our own for creating animated effects -----------------
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<strip.numPixels(); i++) { // For each pixel in strip...
strip.setPixelColor(i, color); // Set pixel's color (in RAM)
strip.show(); // Update strip to match
delay(wait); // Pause for a moment
