Adafruit Neopixel RGBW Clock using SK6812
Hello all
I’m working on an RGBW LED Clock using a single strip of SK6812 using 72 pixels/LEDS.
60 pixels will be used as seconds and minutes, while 12 pixels will be used for hours.
Using Adafruit’s Neopixel library - I use a for loop to flash each pixel red to represent a second, from the 0th pixel to the 60th pixel. Again, the red colour represents a second.
Once the 60th LED is lit, the process starts all over again, but the first LED is now also blue, to indicate that a minute has gone pass - I use a global variable counter to keep track of the minutes that have passed, and use this variable as an argument for the strip.fill function.
Once the 60th LED has flashed blue, I want the 61th pixel to light green to indicate an hour - the second/minute double loop should repeat until the 72th pixel is lit green (12th hour) and then the seconds/minute and hour loops are back to zero.
However for some reason, the 61th to 72nd pixel all light up simultaneously, as seen in the video
Here is my code
  RGBW CLOCK
  Version 2
  28/06/2020
  Version 2 - Minutes now work, however hours does not.
// NeoPixel test program showing use of the WHITE channel for RGBW
// pixels only (won't look correct on regular RGB NeoPixel strips).
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN     6
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT  72
// NeoPixel brightness, 0 (min) to 255 (max)
#define BRIGHTNESS 100
// DELAY VALUE
int delayval = 1;
// COUNTER VALUES
int j = 0; // FOR MINUTES
int k = 61; // FOR HOURS
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRBW + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
  // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  // Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  // END of Trinket-specific code.
  strip.begin();           // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();            // Turn OFF all pixels ASAP
  strip.setBrightness(10); // Set BRIGHTNESS to about 1/5 (max = 255)
  // Fill along the length of the strip in various colors...
  singleLED(strip.Color(255,   0,   0)     , strip.Color(0,   0,   255), strip.Color(0,   255,   0),  delayval); // three color objects and a delay value
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
//COLOURS OF THE CLOCK - RED FOR SECONDS, BLUE FOR MINUTES, GREEN FOR HOURS
void singleLED(uint32_t colorSeconds, uint32_t colorMinutes, uint32_t colorHours,  int wait) {
  for (int i = 0; i < 60; i++) { // For each pixel in strip...
    // COUNTER
    if (i == 59) {
      j++;
      Serial.println(j);
      if (j == 61) {
        j = 0;
        k++;
        Serial.println(k);
        strip.clear();
    // TURN ON LEDS FOR MINUTES
    if (j >= 1) {
      strip.fill(colorMinutes, 0, j);
      strip.show();
    // TURN ON LEDS FOR HOURS
    if (k >= 62) {
      strip.fill(colorHours, 60, k);
      strip.show();
    // TURN ON LEDS FOR SECONDS
    strip.setPixelColor(i, colorSeconds);
    strip.show();
    //  Update strip to match
    delay(wait);                           //  Pause for a moment
    strip.clear();
Here’s the snippet of code responsible for the green LEDS:
    if (k >= 62) {
      strip.show();
I don’t know why this code would flash all 61th-72nd leds…
Looking forward to your reply :slight_smile:
Kind Regards
Dennis
I don't know why this code would flash all 61th-72nd leds....
I don't think you read the documentation for strip.fill() carefully enough, or understood it. Read it again and see if you can figure out what you are doing wrong.
