I am quite new to Arduino and have no programming background so far. For a project in university we need to make something with Arduino. What I have isa Touch sensor, that when Touching it turns the Neopixel Ring on. What I want to do is to turn the Neopixel Ring on and make it turn off automatically again after 2-3 seconds. However so far, it only turns off, when I touch the touch sensor again. Any ideas on how I can achieve that? I provided the code below for reference:
#include <Adafruit_NeoPixel.h> //Include the NeoPixel library
#define NEO_PIN 6 // DIGITAL IO pin for NeoPixel OUTPUT from GEMMA
#define TOUCH_PIN 3 // DIGITAL IO pin for momentary touch sensor INPUT to GEMMA
#define PIXEL_COUNT 12 // Number of NeoPixels connected to GEMMA
#define DELAY_MILLIS 10 // delay between blinks, smaller numbers are faster
#define DELAY_MULT 8 // Randomization multiplier on the delay speed of the effect
#define BRIGHT 100 // Brightness of the pixels, max is 255
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number on Arduino (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_GRB Pixels are wired for GRB bitstream, correct for neopixel stick (most NeoPixel products)
// NEO_KHZ400 400 KHz bitstream (e.g. FLORA pixels)
// NEO_KHZ800 800 KHz bitstream (e.g. High Density LED strip), correct for neopixel stick
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(PIXEL_COUNT, NEO_PIN, NEO_GRB + NEO_KHZ800);
bool oldState = HIGH; //sets the initial variable for counting touch sensor button pushes
int showColor = 0; //color mode for cycling
pinMode(TOUCH_PIN, INPUT); //Initialize touch sensor pin as input using external pull-up resistor
pixels.begin();
pixels.setBrightness(BRIGHT);
pixels.show(); //Set all pixels to "off"
int RColor = 255; //color (0-255) values to be set by cylcing touch switch, initially GOLD
int GColor = 0 ;
int BColor = 0 ;
if (showColor==0) { // Black off
RColor = 0;
GColor = 0;
BColor = 0;
if (showColor==1) {// Alchemy Blue
RColor = 50;
GColor = 255;
BColor = 255;
if (showColor==2) {// Black off
RColor = 0;
GColor = 0;
BColor = 0;
if (showColor==3) {// Tinker Green
RColor = 0;
GColor = 255;
BColor = 40;
if (showColor==4) {//Black off
RColor = 0;
GColor = 0;
BColor = 0;
//sparkling
int p = random(PIXEL_COUNT); //select a random pixel
pixels.setPixelColor(p,RColor,GColor,BColor); //color value comes from cycling state of momentary switch
pixels.show();
//button check to cycle through color value sets
bool newState = digitalRead(TOUCH_PIN); //Get the current button state
// Check if state changed from high to low (button press).
if (newState == LOW && oldState == HIGH) {
// Short delay to debounce button.
delay(20);
// Check if button is still low after debounce.
if (newState == LOW) {
showColor++;
if (showColor > 3)
showColor=0;
// Set the last button state to the old state.
oldState = newState;
