Adafruit NeoPixel won't output a solid color
I got an [Adafruit NeoPixel Ring 16x RGBW cool] and i am trying to make an ironman arc reactor but i can't get the neo pixel to show a consistent color keep in mind i just got this thing and still have no clue how to code it but with the example sketches i can't get a real color it's just Red Green Blue but Green is mostly white the only color tha does work is white I want to have just a solid blue nothing else but i don't know what to do.
Just a wild guess but make sure you're using the library for RGBW and not the RGB library.
I suggest you read the forum guide
Also it helps if you write in sentences.
You could post the code you are using in code tags, post an image of your project all wired up and you could post a schematic.
Also, could you be a bit clearer on what issue you are having with the NeoPixel thingy?
Solid blue would be 0,255,0 sent to all the connected neopixels.
leds.setPixelColor(position, leds.Color( 0, 0, 255));
Would set the neos to blue.
Unless they were RGBW of course. :face_with_raised_eyebrow:
