Adafruit PCA9615 and dhlt11 sensor
Can I use this extende (Afafruit 9615) to remotely connect the dht11 sensor? If so how should I connect it?
Thank you
Is the DHT11 sensor a I2C device?
The DHT11 is a basic, low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins needed). Adafruit posts a library which will you to read it. This took about 30 seconds with Google to confirm my answer, did you try?
