Adafruit PIR Sensor - troubleshooting code
So I'm trying to send a serial string when the sensor detects motion and then every ten seconds thereafter. I can't find what's wrong with my code, but the sensor works with other sketches and the serial connection works. Any ideas? Much obliged.
const int pirPin = A0;
long lastmotion;
long now;
int LED = 13;
bool pirON = false;
  pinMode(pirPin, INPUT);
  now = millis(); // assign counter to current time...ish
  if (digitalRead(pirPin) == HIGH){  // if motion detected
    digitalWrite(LED, HIGH);
    if (pirON = false){    //if previous motion didn't happen
      Serial.println("item=motionevent;");
      pirON = true;      // establish that a previous event happened
      lastmotion = now;  // establish time of last event
  if (pirON = true){    //if event happened
    if (now > (lastmotion+10000l)){   // and it was more than ten seconds ago
      pirON = false;                 // reset previous motion event
      digitalWrite(LED, LOW);
You haven't said what it's doing that's wrong....
Classic C pitfall. This:
should be:
  if (pirON == true){    //if event happened
That's probably it - thank you! Will test now...
