Adafruit PN532 Help
Hey all,
I'm using the Adafruit PN532 RFID/NFC shield
with a Leonardo.
My end goal is to write a number between 1 and 10 to a Mifare classic card. I can do this part, but I'm then having trouble reading it back. I'm using the Adafruit library from the tutorial. I've slightly modified the mifareclassic_memdump example sketch so it looks like the code below:
    @file     mifareclassic_memdump.pde
    @author   Adafruit Industries
  @license  BSD (see license.txt)
    This example attempts to dump the contents of a Mifare Classic 1K card
    Note that you need the baud rate to be 115200 because we need to print
  out the data and read from the card at the same time!
    This is an example sketch for the Adafruit PN532 NFC/RFID breakout boards
    This library works with the Adafruit NFC breakout
      ----> https://www.adafruit.com/products/364
    Check out the links above for our tutorials and wiring diagrams
    These chips use SPI or I2C to communicate
    Adafruit invests time and resources providing this open source code,
    please support Adafruit and open-source hardware by purchasing
    products from Adafruit!
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_PN532.h>
// If using the breakout with SPI, define the pins for SPI communication.
#define PN532_SCK  (6)
#define PN532_MOSI (3)
#define PN532_SS   (4)
#define PN532_MISO (5)
// If using the breakout or shield with I2C, define just the pins connected
// to the IRQ and reset lines.  Use the values below (2, 3) for the shield!
#define PN532_IRQ   (6)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
// Uncomment just _one_ line below depending on how your breakout or shield
// is connected to the Arduino:
// Use this line for a breakout with a SPI connection:
//Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
// Use this line for a breakout with a hardware SPI connection.  Note that
// the PN532 SCK, MOSI, and MISO pins need to be connected to the Arduino's
// hardware SPI SCK, MOSI, and MISO pins.  On an Arduino Uno these are
// SCK = 13, MOSI = 11, MISO = 12.  The SS line can be any digital IO pin.
//Adafruit_PN532 nfc(PN532_SS);
// Or use this line for a breakout or shield with an I2C connection:
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
void setup(void) {
  // has to be fast to dump the entire memory contents!
  while (!Serial) delay(10); // for Leonardo/Micro/Zero
  Serial.println("Looking for PN532...");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;                          // Flag to check if there was an error with the PN532
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  uint8_t currentblock;                     // Counter to keep track of which block we're on
  bool authenticated = false;               // Flag to indicate if the sector is authenticated
  uint8_t data[16];                         // Array to store block data during reads
  // Keyb on NDEF and Mifare Classic should be the same
  uint8_t keyuniversal[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      // Now we try to go through all 16 sectors (each having 4 blocks)
      // authenticating each sector, and then dumping the blocks
      for (currentblock = 0; currentblock < 5; currentblock++)
        // Check if this is a new block so that we can reauthenticate
        if (nfc.mifareclassic_IsFirstBlock(currentblock)) authenticated = false;
        // If the sector hasn't been authenticated, do so first
        if (!authenticated)
          // Starting of a new sector ... try to to authenticate
          Serial.print("------------------------Sector ");Serial.print(currentblock/4, DEC);Serial.println("-------------------------");
          if (currentblock == 0)
              // This will be 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF for Mifare Classic (non-NDEF!)
              // or 0xA0 0xA1 0xA2 0xA3 0xA4 0xA5 for NDEF formatted cards using key a,
              // but keyb should be the same for both (0xFF 0xFF 0xFF 0xFF 0xFF 0xFF)
              success = nfc.mifareclassic_AuthenticateBlock (uid, uidLength, currentblock, 1, keyuniversal);
              // or 0xD3 0xF7 0xD3 0xF7 0xD3 0xF7 for NDEF formatted cards using key a,
          if (success)
            authenticated = true;
            Serial.println("Authentication error");
        // If we're still not authenticated just skip the block
        if (!authenticated)
          Serial.print("Block ");Serial.print(currentblock, DEC);Serial.println(" unable to authenticate");
          // Authenticated ... we should be able to read the block now
          // Dump the data into the 'data' array
          success = nfc.mifareclassic_ReadDataBlock(currentblock, data);
          if (success)
            // Read successful
            // Dump the raw data
            nfc.PrintHexChar(data, 12);
            // Oops ... something happened
            Serial.println(" unable to read this block");
      Serial.println("Ooops ... this doesn't seem to be a Mifare Classic card!");
  // Wait a bit before trying again
  Serial.println("\n\nSend a character to run the mem dumper again!");
  Serial.flush();
  while (!Serial.available());
  while (Serial.available()) {
  Serial.read();
  Serial.flush();
I have written the value "xx1" (The xx's are temporary, just so I could make the value stand out) and the output from my code looks like this:
17:59:57.912 -> Found an ISO14443A card
17:59:57.912 -> UID Length: 4 bytes
17:59:57.912 -> UID Value: 0x04 0x41 0x15 0x4C
17:59:57.912 ->
17:59:57.912 -> Seems to be a Mifare Classic card (4 byte UID)
17:59:57.912 -> ------------------------Sector 0-------------------------
17:59:58.006 -> Block 004 41 15 4C 1C 88 04 00 C8 09 00 20 .A.L.⸮..⸮..
17:59:58.053 -> Block 114 01 03 E1 03 E1 03 E1 03 E1 03 E1 ...⸮.⸮.⸮.⸮.⸮
17:59:58.101 -> Block 203 E1 03 E1 03 E1 03 E1 03 E1 03 E1 .⸮.⸮.⸮.⸮.⸮.⸮
17:59:58.148 -> Block 300 00 00 00 00 00 78 77 88 C1 00 00 ......xw⸮⸮..
17:59:58.148 -> ------------------------Sector 1-------------------------
17:59:58.241 -> Block 400 00 03 08 D1 01 04 55 01 78 78 31 ....⸮..U.xx1
17:59:58.241 ->
17:59:58.241 ->
17:59:58.241 -> Send a character to run the mem dumper again!
Blockquote
How can I just get to the 'xx1' value?
Thanks!
It looks like your 'value' is in Sector 1, Block4, bytes 9-11 so after reading them in, pull them out of your 'data' array
I had already tried
Serial.println(data[0]);
I've tried replacing 0 with lots of different numbers from 0 all the way through to 30, it never seems to show up as a number that I would expect.
Thanks
data is of type uint8_t so when you print out one of those elements, you are getting the ascii code associated with "xx1" in hex, it would be 78 78 31 but since you are printing it out as a decimal, you are getting 120 120 49.
if you create a string
char buffer[5];
.... // read the card
buffer[0] = data[9];
buffer[1] = data[10];
buffer[2] = data[11];
buffer[3] = '\0';  // terminate string
Serial.println( buffer );
