Hallo
Ich habe mir letztens einen Adafruit Pro Trinkte zugelegn und wollte an dem das Ultimate GPS Modul betreiben... Aber es scheint dass da irgendwo bytes nicht übertragen werden... Hier jedenfalls die Ausgabe vom Pro Trinket
$GPRMC,000336.800,V,,,,,0.00,0.00,060180,,,N*4C
PG.00,,,0N.00,N2$GPGGA,000337.800 ,,,,,0,00,,,M,,M,,*77
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$V,00,T,00,.00,30,V,,,,,0.00,0.00,060180,,,N*4D
$GPGGA,000338.800,,,,,0,00,,,M,,M,,*78
$GPGSV,1,1,00*79
$GPGGA,000339.800,,,,,0,00,,,M,,M,,*79$V,0.0,,00,0.0K*
GT000,TM.,0.00,3$GPGGA,000340.800,,,,,0,00,,,M,,M,,*77
$GPGGA,000341.800,,,,,0,00,,,M,,M,,*76
$V,00,T,.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4C
$GPGGA,000342.800,,,,,0,00,,,M,,M,,*75
GT000,TM.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4F
$GPGGA,000343.800,,,,,0,00,,,M,,M,,*74
$GPGSV,1,1,00*79
$GPRMC,000343.800,V,,,,,0.00,0068,,,NE$V,0.00,,0,0.0,N2$GPGGA,000344.800,,,,,0,00,,,M,,M,,*73
$GPRMC,000344.800,V,,,,,0.00,0.00,060180,,,N*49
PG.00,,,0N.00,N2$GPGGA,000345.800,,,,,0,00,,,M,,M,,*72
GT000,TM.,0.0,N2$GPGGA,000346.800,,,,,0,00,,,M,,M,,*71
$T000,T,000.00,30,V,,,,,0.00,0.00,060180,,,N*4B
$GPGGA,000347.800,,,,,0,00,,,M,,M,,*70
PG.00,TM.N.00,N2$GPGGA,000348.800,,,,,0,00,,,M,,M,,*7F
$GPGSV,1,1,00*79
GT0.00TM.,,0.0,30,V,,,,,0.00,.,00,,,*
$GPGGA,000349.800,,,,,0,00,,,M,,M,,*7E
GG.00,TM.,0.0,N2$GPGGA,000350.800,,,,,0,00,,,M,,M,,*76
$GPRMC,000350.800,V,,,,,0.00,0.00,060180,,,N*4C
PG.00,TM.N.00,N2$GPGGA,000351.800,,,,,0,00,,,M,,M,,*77
$V,00,T,00,.00K*0,V,,,,,0.00,0.00,060180,,,N*4D
$GPGGA,000352.800,,,,,0,00,,,M,,M,,*74
PG.00,,,0N.00,N2$GPGGA,000353.800,,,,,0,00,,,M,,M,,*75
$GPGSV,1,1,00*79
$GPGGA,000354.800,,,,,0,00,,,M,,M,,*72
$T000,T,00,.00,30,V,,,,,0.00,0.00,060180,,,N*48
$GPGGA,000355.800,,,,,0,00,,,M,,M,,*73
$V000,T,00,.00,30,V,,,,,0.00,0.00,060180,,,N*49
$GPGGA,000356.800,,,,,0,00,,,M,,M,,*70
GT000,T,.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4A
$GPGGA,000357.800,,,,,0,00,,,M,,M,,*71
GT.00,TM.,0.0,N2$GPGGA,000358.800,,,,,0,00,,,M,,M,,*7E
$GPGSV,1,1,00*79
$GPRMC,000358.800,V,,,,,0.00,0001,,,N4
PG0.00,,0N,0.,N2$GPGGA,000359.800,,,,,0,00,,,M,,M,,*7F
$GPRMC,000359.800,V,,,,,0.00,0.00,060180,,,N*45
PG.00,,,0N.00,N2$GPGGA,000400.800,,,,,0,00,,,M,,M,,*74
PG.00,,,0N.00,N2$GPGGA,000401.800,,,,,0,00,,,M,,M,,*75
$GPRMC,000401.800,V,,,,,0.00,0.00,060180,,,N*4F
PG.00,,,0N.00,N2$GPGGA,000402.800,,,,,0,00,,,M,,M,,*76
GT000,TM.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4C
$GPGGA,000403.800,,,,,0,00,,,M,,M,,*77
$GPGSV,1,1,00*79
$GPRMC,000403.800,V,,,,,0.00,0001,,,N4
PG0.00,,0N,0.,N2$GPGGA,000404.800,,,,,0,00,,,M,,M,,*70
$GPRMC,000404.800,V,,,,,0.00,0.00,060180,,,N*4A
PG.00,T,0N.00,N2$GPGGA,000405.800,,,,,0,00,,,M,,M,,*71
$T000,T,00,.00,30,V,,,,,0.00,0.00,060180,,,N*4B
$GPGGA,000406.800,,,,,0,00,,,M,,M,,*72
GT.00,TM.,0.00,3$GPGGA,000407.800,,,,,0,00,,,M,,M,,*73
GT000,TM.,0.0,N2$GPGGA,000408.800,,,,,0,00,,,M,,M,,*7C
$GPGSV,1,1,00*79
$GPGGA,000409.800,,,,,0,00,,,M,,M,,*7D$V0.00,,00,0.0K*
$V,00,T,00,.00K30,V,,,,,0.00,0.00,060180,,,N*47
$GPGGA,000410.800,,,,,0,00,,,M,,M,,*75
$GPGGA,000411.800,,,,,0,00,,,M,,M,,*74
$GPRMC,000411.800,V,,,,,0.00,0.00,060180,,,N*4E
$GPGGA,000412.800,,,,,0,00,,,M,,M,,*77 PG00,T,,0N.00,N
$T000,TM.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4D
$GPGGA,000413.800,,,,,0,00,,,M,,M,,*76
$GPGSV,1,1,00*79
$GPRMC,000413.800,V,,,,,0.00,0001,,,N4
PG0.00,,0N,0.,N2$GPGGA,000414.800,,,,,0,00,,,M,,M,,*71
GT000,TM.,0.00,30,V,,,,,0.00,0.00,060180,,,N*4B
Und hier direkt mit dem Kabel..
$GPVTG,0.00,T,,M,0.00,N,0.00,K,N*32
$GPGGA,235958.800,,,,,0,00,,,M,,M,,*70
$GPGSV,1,1,00*79
$GPRMC,235958.800,V,,,,,0.00,0.00,050180,,,N*49
$GPGGA,235959.800,,,,,0,00,,,M,,M,,*71
$GPRMC,235959.800,V,,,,,0.00,0.00,050180,,,N*48
$GPGGA,000000.800,,,,,0,00,,,M,,M,,*70
$GPRMC,000000.800,V,,,,,0.00,0.00,060180,,,N*4A
$GPGGA,000001.800,,,,,0,00,,,M,,M,,*71
$GPRMC,000001.800,V,,,,,0.00,0.00,060180,,,N*4B
$GPGGA,000002.800,,,,,0,00,,,M,,M,,*72
$GPRMC,000002.800,V,,,,,0.00,0.00,060180,,,N*48
$GPGGA,000003.800,,,,,0,00,,,M,,M,,*73
$GPGSV,1,1,00*79
$GPRMC,000003.800,V,,,,,0.00,0.00,060180,,,N*49
$GPGGA,000004.800,,,,,0,00,,,M,,M,,*74
$GPRMC,000004.800,V,,,,,0.00,0.00,060180,,,N*4E
$GPGGA,000005.800,,,,,0,00,,,M,,M,,*75
$GPRMC,000005.800,V,,,,,0.00,0.00,060180,,,N*4F
$GPGGA,000006.800,,,,,0,00,,,M,,M,,*76
$GPRMC,000006.800,V,,,,,0.00,0.00,060180,,,N*4C
$GPGGA,000007.800,,,,,0,00,,,M,,M,,*77
$GPRMC,000007.800,V,,,,,0.00,0.00,060180,,,N*4D
Hier der Sketch den ich verwende
#include <SoftwareSerial.h>
#define rx 6
#define tx 5
SoftwareSerial mySerial(rx, tx); // RX, TX
pinMode(rx, INPUT);
pinMode(tx, OUTPUT);
// Serial1.begin(9600);
mySerial.begin(9600);
pinMode(13,OUTPUT);
if (mySerial.available()) {
Serial.write(mySerial.read());
digitalWrite(13,HIGH);
if (Serial.available()){
mySerial.write(Serial.read());
digitalWrite(13,LOW);
Interesanterweise hats mit dem Seeeduino perfekt funktioniert... Hab dann auch noch einen externen Spannungsregler zugeschaltet um einen ev. Spannungsabfall vorzubeugen aber immer das gleiche.. Kanns sein dass der Chip das nicht kann oder ist der Pro Trinket defekt?
mfg
