I have a tft display (1.8") (Adafruit QDTech Library) and a relay connected to an arduino nano. the relay is connected to pin 12, where it is activated when the pin is LOW.
The following code works, setting pin 12 to LOW (0V) in the loop, and activating the relay. However, if I activate the display - uncomment tft.init(); - pin 12 shows 3.7V in LOW.
Is this a software problem / conflict?
Thanks in advance!
// TFT DISPLAY //
#include <SPI.h>
#include "Adafruit_GFX.h" // Core graphics library
#include "Adafruit_QDTech.h" // Hardware-specific library
#define sclk 13 // Don't change
#define mosi 11 // Don't change
#define cs 9
#define dc 8
#define rst 7 // you can also connect this to the Arduino reset
Adafruit_QDTech tft = Adafruit_QDTech(cs, dc, rst); // Display-Bibliothek Setup
// RELAY
int relay = 12;
// RELAY: initialize the digital pin as an output.
pinMode(relay, OUTPUT);
//Display Setup
// tft.init();
digitalWrite(relay, LOW);
