I am trying to use the Adafruit Tiny USB on a custom variant I have on a SAMD51 microcontroller. I have changed the files accordingly.
I tried using two examples that Adafruit has provided.
"msc_ramdisk" example works fine and my device is identified as a mass storage device. The problem here is it has only about 6KB memory since its the the ram.
"msc_sd" is the example I really want to work but for some reason it is showing USB device not recognized on my PC.
Has anyone being able to set the Adafruit Tiny USB
I am also working on SAMD51, I try to reduce the power consumption.
In sleep mode (0x04) I have 2.9 mA. In a previous post you mentioned
"By initializing the pins to tri-state buffers, I was able to reach a current consumption of 120uA. Any idea to reach double digits?" -> What do you mean exactly ? is it putting GPIO to output low ?
I am struggling to reduce the power consumption below 1mA
