Adafruit Trellis with a Pro Micro and Mega 2560
So I’ve purchased an Adafruit Trellis: Connecting | Introducing Adafruit Trellis | Adafruit Learning System
Here is the sketch for the componenet:
  This is a test example for the Adafruit Trellis w/HT16K33
  Designed specifically to work with the Adafruit Trellis
  ----> https://www.adafruit.com/products/1616
  ----> https://www.adafruit.com/products/1611
  These displays use I2C to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_Trellis.h"
  This example shows reading buttons and setting/clearing buttons in a loop
  "momentary" mode has the LED light up only when a button is pressed
  "latching" mode lets you turn the LED on/off when pressed
  Up to 8 matrices can be used but this example will show 4 or 1
#define MOMENTARY 0
#define LATCHING 1
// set the mode here
#define MODE LATCHING
Adafruit_Trellis matrix0 = Adafruit_Trellis();
// uncomment the below to add 3 more matrices
Adafruit_Trellis matrix1 = Adafruit_Trellis();
Adafruit_Trellis matrix2 = Adafruit_Trellis();
Adafruit_Trellis matrix3 = Adafruit_Trellis();
// you can add another 4, up to 8
// Just one
Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0);
// or use the below to select 4, up to 8 can be passed in
//Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0, &matrix1, &matrix2, &matrix3);
// set to however many you're working with here, up to 8
#define NUMTRELLIS 1
#define numKeys (NUMTRELLIS * 16)
// Connect Trellis Vin to 5V and Ground to ground.
// Connect the INT wire to pin #A2 (can change later!)
#define INTPIN A2
// Connect I2C SDA pin to your Arduino SDA line
// Connect I2C SCL pin to your Arduino SCL line
// All Trellises share the SDA, SCL and INT pin!
// Even 8 tiles use only 3 wires max
  Serial.println("Trellis Demo");
  // INT pin requires a pullup
  pinMode(INTPIN, INPUT);
  digitalWrite(INTPIN, HIGH);
  // begin() with the addresses of each panel in order
  // I find it easiest if the addresses are in order
  trellis.begin(0x70);  // only one
  // trellis.begin(0x70, 0x71, 0x72, 0x73);  // or four!
  // light up all the LEDs in order
  for (uint8_t i=0; i<numKeys; i++) {
    trellis.setLED(i);
    trellis.writeDisplay();
    delay(50);
  // then turn them off
    trellis.clrLED(i);
    delay(50);
  delay(30); // 30ms delay is required, dont remove me!
  if (MODE == MOMENTARY) {
    // If a button was just pressed or released...
    if (trellis.readSwitches()) {
      // go through every button
	// if it was pressed, turn it on
	if (trellis.justPressed(i)) {
	  Serial.print("v"); Serial.println(i);
	  trellis.setLED(i);
	// if it was released, turn it off
	if (trellis.justReleased(i)) {
	  Serial.print("^"); Serial.println(i);
	  trellis.clrLED(i);
      // tell the trellis to set the LEDs we requested
  if (MODE == LATCHING) {
        // if it was pressed...
	  Serial.println(i);
	  // Alternate the LED
	  if (trellis.isLED(i))
	    trellis.clrLED(i);
	    trellis.setLED(i);
What I want to do is run this sketch on a Pro Micro and then potentially send the information to the main board I will be using which is an Arduino Mega 2560. What i’m wondering is if you can send serial from one board to another? And if so, how?
Cheers
What i'm wondering is if you can send serial from one board to another? And if so, how?
Yes you can. Serial.print() the data from the Pro Micro and Serial.read() it on the Mega. It is may be more convenient to use SoftwareSerial to send the data because you get to choose which Tx and Rx pins to use and can still use Serial for debugging.
There are SoftwareSerial examples in the IDE
Ok, cheers. So if I still want to use rx0, i'm assuming i can use rx1 do Serial1.read()? As I want to be able to use the Mega as normal for sensor use, and jus receive the serial message from the micro.
The Mega has 4 hardware serial ports so there is no need to use SoftwareSerial. Thinking about it, the Micro has a second Serial port as well so no need to use SoftwareSerial on that either.
