Adafruit Ultrasonicsoundsencor not working
Hello I want to make a stair light using a Arduino UNO and two ultrasonic sound sensors but when I simulate using Tinkercad the LEDstrips turn on when i set the sensor lower than 80cm but then they dont turn off when i turn the sensor above 80cm.
This is the code i have for now, i am going to add a fade and another sensor but i want to test the turn on turn of thingy
long readUltrasonicDistance(int triggerPin, int echoPin)
  pinMode(triggerPin, OUTPUT);  // Clear the trigger
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  // Sets the trigger pin to HIGH state for 10 microseconds
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  pinMode(echoPin, INPUT);
  // Reads the echo pin, and returns the sound wave travel time in microseconds
  return pulseIn(echoPin, HIGH);
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1:
#define LED_PIN    2
// How many NeoPixels are attached to the Arduino?
#define LED_COUNT 8
// Declare our NeoPixel strip object:
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
// Argument 1 = Number of pixels in NeoPixel strip
// Argument 2 = Arduino pin number (most are valid)
// Argument 3 = Pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
  // Initialize the NeoPixel library.
  strip.begin();
   uint32_t wit = strip.Color(255, 251, 230);
  strip.fill(wit, 0, 8);
 if (0.01723 * readUltrasonicDistance(3, 3) < 80) { strip.show();
{delay(10);
 if (0.01723 * readUltrasonicDistance(3, 3) > 80) { strip.clear();
Does that even compile?
Can you have the trigger and echo on the same pin?
no i found that out like 2 mins ago i think i am going to use some pir sensors becouse thats a bit easyer for me
