Adafruit vs1053 example not working with uno r4 wifi
hi everyone,
i recently got the new uno r4 wifi and i am trying to run the player_simple vs1053 example sketch but keep getting an error message that reads
In file included from /private/var/folders/7w/mhv5s7ws3plgn51z1s3lvcyc0000gn/T/.arduinoIDE-unsaved20231029-21592-g5ew39.jj6i9/player_simple/player_simple.ino:17:0:
/Users/[redacted my private info]/Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.h:17:10: fatal error: wiring_private.h: No such file or directory
 #include "wiring_private.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
i am running arduino IDE 2.1.1 and just downloaded the latest github library for the vs1053 codec, i even tried editing the .h file to comment out the #include "wiring_private.h" line but that didn't work at all
i cannot figure out what this means and can't seem to find a post particular to my issue and apologies if it has.
thank you in advance for your help!
Do a forum search for: r4 wiring_private and you'll see that it's unfortunately a common problem with many libraries and the R4.
Starting with the information in
You could try editing the library's header file Adafruit_VS1053.h and change line 17 to:
#if defined(__has_include)
#if __has_include("wiring_private.h")
#endif  // __has_include("wiring_private.h")
#else  //defined(__has_include)
#endif  //defined(__has_include)
and see if that gets you closer to the finish.
thank you so much for such a quick response!
i took your advice and it did get rid of the wiring_private.h error!! ty!
but now shows:
/Users/Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.h:15:0: error: unterminated #if
 #if !defined(ARDUINO_STM32_FEATHER)
/Users/Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.h:5:0: error: unterminated #ifndef
 #ifndef ADAFRUIT_VS1053_H
exit status 1
i am going to read more into this on the link you sent right now
thank you again
just an update on this, i re-downloaded and installed the adafruit vs1053 library right now and edited the wiring_private.h lines and am now getting completely new errors. any help is appreciated, also if anybody knows an mp3 board that is compatible with the r4 wifi please let me know i have a final project due soon :smiling_face_with_tear:
In file included from /Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.h:9:0,
                 from /Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.cpp:26:
/Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.cpp: In constructor 'Adafruit_VS1053::Adafruit_VS1053(int8_t, int8_t, int8_t, int8_t, int8_t, int8_t, int8_t)':
/Users//Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/Arduino.h:75:92: error: cannot convert 'volatile uint16_t* {aka volatile short unsigned int*}' to 'PortReg* {aka volatile long unsigned int*}' in assignment
 #define portOutputRegister(port)    &(((R_PORT0_Type *)IOPORT_PRV_PORT_ADDRESS(port))->PODR)
/Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.cpp:366:16: note: in expansion of macro 'portOutputRegister'
   clkportreg = portOutputRegister(digitalPinToPort(_clk));
/Users//Library/Arduino15/packages/arduino/hardware/renesas_uno/1.0.5/cores/arduino/Arduino.h:76:92: error: cannot convert 'const volatile uint16_t* {aka const volatile short unsigned int*}' to 'PortReg* {aka volatile long unsigned int*}' in assignment
 #define portInputRegister(port)     &(((R_PORT0_Type *)IOPORT_PRV_PORT_ADDRESS(port))->PIDR)
/Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.cpp:368:17: note: in expansion of macro 'portInputRegister'
   misoportreg = portInputRegister(digitalPinToPort(_miso));
/Users//Documents/Arduino/libraries/Adafruit_VS1053_Library/Adafruit_VS1053.cpp:370:17: note: in expansion of macro 'portOutputRegister'
   mosiportreg = portOutputRegister(digitalPinToPort(_mosi));
exit status 1
I've got the same problem. Super sucks that the Uno R4 compatibility chart shows that the music maker shield is supported. I guess you can't expect much from $10 toys. Total waste of money. BTW, here is where it says it supposed to be supported https://docs.arduino.cc/tutorials/uno-r4-minima/shield-compatibility
Sounds like a "left hand doesn't know what the right hand's doing" situation. Looking at
the music maker shield doesn't appear in that compatibility list.
But, looking through the open pulls in the Adafruit VS1053 library, someone may have already solved your problem:
Hmm, it looks like someone is working on it. I just tried downloading that guys branch and installed the library, but it still fails. Correction, it works with Uno R4 wifi, but not minima.
In constructor 'Adafruit_VS1053::Adafruit_VS1053(int8_t, int8_t, int8_t, int8_t, int8_t, int8_t, int8_t) blah blah blah, 100 more lines of errors.
May i ask which fork you used to compile for Uno R4 Wifi?
