I'm using the Wifi101 library. When I run the ScanNetworks (or ScanNetworksAdvanced) sketch I get the following output:
MAC: F8:F0:05:A6:03:0E
Scanning available networks...
** Scan Networks **
number of available networks:3
0) Betelgeuse Signal: -38 dBm Encryption: WPA
- Pollux Signal: -38 dBm Encryption: None
- Signal: -59 dBm Encryption: WPA
It's what I expect.
When I run the "ConnectNoEncryption" sketch using the Pollux network, i can successfully connect.
Attempting to connect to open SSID: Pollux
You're connected to the networkSSID: Pollux
BSSID: 86:D2:94:2D:F3:B5
signal strength (RSSI):-38
Encryption Type:1
IP Address: 192.168.1.24
192.168.1.24
MAC address: F8:F0:05:A6:03:0E
NetMask: 255.255.255.0
Gateway: 192.168.1.1
When I run the "ConnectWPA" sketch using the Betelgeuse I repeatedly get "Attempting to connect to WPA SSID: Betelgeuse" messages.
Checking the router log (its and Orbi RBR50 with one satellite) I see the error message
"[WLAN access rejected: incorrect security] from MAC address f8:f0:05:a6:03:0e"
So I check the "arduino_secrets.h" sketch tab and the correct SSID and password are in the appropriate #defines with the correct capitalization and spacing in the SSID and password.
I've looked in the Wifi101 library for methods that may exist to help in troubleshooting this problem but can't find any.
Any comments, questions, suggestions that might help to resolve this are greatly appreciated.
TNX
