Adafruit_ASFCore library compile errors
This is an update to the earlier post at Arduino ZERO timer interrupts.
I'm having problems compiling the GitHub - adafruit/Adafruit_ASFcore: ASF core files for Zero library. It successfully compiles using the Arduino desktop IDE, but not the Arduino web IDE.
I even made the suggested fix that avandalen mentions in his post at SAMD21 Timer library for the Arduino Zero.
I began to debug, and fixed several #include errors, but finally quit in exasperation. It seems that several Adafruit_ASFcore header files are not compatible with the Arduino web IDE.
After the compilation fails click the copy icon at the top right corner of the black console window (you might have to drag the divider at the bottom of the editor window to make the console window show). Then paste it in a reply here using code tags.
Here is the log file, as pert requested. I had to attach the log, as it is too big to put into a quote (9000 character limit).
I made the following changes to the Adafruit_ASFcore library before uploading to the Arduino web IDE:
  1. In system_interrupt.h, commented out the right-brace on line 426 as suggested by avandalen.
  2. Moved the files from preprocessor/preprocessor up to preprocessor.
  3. Moved the files from interrupt/interrupt up to interrupt.
Web editor log.txt (17.3 KB)
I confirm the issue. Note that it also occurs with the beta build of the Arduino IDE. This indicates the problem is probably with arduino-preprocessor. I have reported the issue, with minimum steps to reproduce the problem, here:
For some reason they decided to turn all Arduino Web Editor users into beta testers without their knowledge, thus you will be more likely to encounter this sort of unpleasant surprise using the Arduino Web Editor. Beta testers are always welcome and that's easy enough by downloading the hourly build or beta build from:
but to subject Arduino Web Editor users, who may be struggling with the basics of programming and electronics, who may have resorted to the Arduino Web Editor because they thought a "cloud based" IDE would be easier than trying to install the standard IDE (false because you still need to install the plugin for the Arduino Web Editor), to use a not fully tested potentially unstable application is insane.
