ADAFRUIT_GFX circle button
I am trying to create a GUI joystick where I draw a circle and everything inside the circle is a variable. While it is easy to detect a touchpoint inside a rectangle, a circle is proving to be difficult. I know I could just make a square inside of my circle but since it is such a large circle that would not work. I thought I could use pythagorean theorem a^2 + b^2 = c^2 and that is what's in my code but it is still choosing a touchpoint outside my circle. I could split it into a bunch of triangles but the memory on a UNO is limited so i'm trying to keep it simple. Here is what I have so far.
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
#define JOYSTICK_X 90   // X= ---->
#define JOYSTICK_Y 150  // Y= ---- UP/DN
#define JOYSTICK_R 30   // JOYSTICK RADIUS
#define KNOB_W 10    // KNOB RADIUS
#define FRAME_W 90 // OUTER RIM RADIUS
int x;
int y;
void drawFrame()
  //tft.drawCircle(JOYSTICK_X, JOYSTICK_Y, JOYSTICK_R, ILI9341_GREEN);
  tft.fillCircle(JOYSTICK_X, JOYSTICK_Y, JOYSTICK_R, 0x07e0);
  tft.drawCircle(JOYSTICK_X, JOYSTICK_Y, FRAME_W, 0x0000);
  //tft.drawCircle(JOYSTICK_X, JOYSTICK_Y, KNOB_W, ILI9341_BLACK);
  tft.fillCircle(JOYSTICK_X, JOYSTICK_Y, KNOB_W, 0xf800); //color in hex
void setup(void)
  tft.begin();
  if (!ts.begin()) {
    Serial.println("Unable to start touchscreen.");
  else {
    Serial.println("Touchscreen started.");
  tft.fillScreen(ILI9341_BLUE);
  // origin = left,top landscape (USB left upper)
  tft.setRotation(1);
  tft.setTextColor(ILI9341_WHITE);
  tft.setTextSize(2);
  tft.setCursor(160,10); tft.println("X = ");
  tft.setCursor(160,30); tft.println("Y = ");
  drawFrame();
void loop(){
  // See if there's any  touch data
  if (!ts.bufferEmpty())
    // Retrieve a point
    TS_Point p = ts.getPoint();
    // Scale using the calibration #'s
    // and rotate coordinate system
    p.x = map(p.x, TS_MINY, TS_MAXY, 0, tft.height());
    p.y = map(p.y, TS_MINX, TS_MAXX, 0, tft.width());
    int y = tft.height() - p.x;
    int x = p.y;
      if ((x*x) + (y*y) <= (FRAME_W * FRAME_W)){  // BEGINNING OF JOYSTICK DECECTION
        tft.fillCircle(JOYSTICK_X,JOYSTICK_Y,KNOB_W,0XF800); //RED
          tft.setTextSize(2);
          tft.setTextColor(0XFFFF);  //WHITE
          tft.setCursor(200,10); tft.println(x);
          tft.setCursor(200,30); tft.println(y);
          delay(10);
          tft.setTextColor(0X001F);
          tft.fillCircle (JOYSTICK_X,JOYSTICK_Y,KNOB_W,0X07E0); //GREEN
  } // end of touch section
}  // end of loop
If this worked correctly the red circle would appear anytime a touchpoint is inside the outer circle and if a touchpoint is outside the outer circle it would change back to green. But since my math is wrong that is not the case. Eventually I will move both circles along the touchpoint but I need to stay inbounds first.
Any help would be greatly appreciated.
